Cold Boot vs Reset
Dear All,
In a previous thread, you helped me build a small "headtracker" using the Wii Motion Plus.
More info is here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1267111521
I got my WM+ working,
driving two Servos that mimic the head movements of the "controller".
My code is here
-> Index of /~mariejul/storage/projects/tuning_people_bots
Anyway, I have a new problem
-> Whenever I plug in the power (or usb) to a Arduino and let it "cold boot",
the Wii Motion Plus does not return any useful data.
I have to reset the Arduino first,
after that everything runs like a charm.
I don't get this.
Cold boot or not, shouldn't the Atmega be doing the exact same thing?
I tought that maybe the WM+ had some sort of start up delay after the power came on. But even when I inserted a 10 second delay as the first line in my setup code, the same thing happened.
Anyone got any explanation for that?
Cheers,
Jim
Also, a quick print of my latest code:
//Trapezoid or Runge-kutta 4th order integration program of wm+
#include <Streaming.h>
#include <Wire.h>
#include <Servo.h>
Servo yawServo;
Servo pitchServo;
int yawServoVal;
int pitchServoVal;
#define steps_per_deg_slow 20
#define steps_per_deg_fast 4
byte data[6]; //six data bytes
int yaw, pitch, roll; //three axes
int yaw0, pitch0, roll0; //calibration zeroes
int time, last_time;
float delta_t;
int last_yaw[3], last_pitch[3], last_roll[3];
float yaw_deg, pitch_deg, roll_deg;
int yaw_deg2, pitch_deg2, roll_deg2;
int startTag=0xDEAD;
int accel_x_axis, accel_y_axis, accel_z_axis;
void wmpOn(){
Wire.beginTransmission(0x53); //WM+ starts out deactivated at address 0x53
Wire.send(0xfe); //send 0x04 to address 0xFE to activate WM+
Wire.send(0x04);
Wire.endTransmission(); //WM+ jumps to address 0x52 and is now active
void wmpSendZero(){
Wire.beginTransmission(0x52); //now at address 0x52
Wire.send(0x00); //send zero to signal we want info
void calibrateZeroes(){
for (int i=0;i<10;i++){
wmpSendZero();
Wire.requestFrom(0x52,6);
for (int i=0;i<6;i++){
data*=Wire.receive();*
  • yaw0+=(((data[3]>>2)<<8)+data[0])/10; //average 10 readings for each zero*
  • pitch0+=(((data[4]>>2)<<8)+data[1])/10;*
  • roll0+=(((data[5]>>2)<<8)+data[2])/10;*
    _ Serial.print("Yaw0:");_
    _ Serial.print(yaw0);_
    _ Serial.print(" Pitch0:");_
    _ Serial.print(pitch0);_
    _ Serial.print(" Roll0:");_
    _ Serial.println(roll0);_
    void receiveData(){
  • wmpSendZero(); //send zero before each request (same as nunchuck)*
  • Wire.requestFrom(0x52,6); //request the six bytes from the WM+*
  • for (int i=0;i<6;i++){*
    _ data*=Wire.receive();_
    _
    }_
    if(bitRead(data[3], 1)==1) yaw=(((data[3]>>2)<<8)+data[0]-yaw0)/steps_per_deg_slow; //see Wiimote/Extension Controllers - WiiBrew*
    * else yaw=(((data[3]>>2)<<8)+data[0]-yaw0)/steps_per_deg_fast;
    if(bitRead(data[3], 0)==1) pitch=(((data[4]>>2)<<8)+data[1]-pitch0)/steps_per_deg_slow; //for info on what each byte represents*
    * else pitch=(((data[4]>>2)<<8)+data[1]-pitch0)/steps_per_deg_fast;
    if(bitRead(data[4], 1)==1) roll=(((data[5]>>2)<<8)+data[2]-roll0)/steps_per_deg_slow;
    else roll=(((data[5]>>2)<<8)+data[2]-roll0)/steps_per_deg_fast;
    _
    }_
    float trapIntegrate(int y2, int y1, float deltax){
    _
    float area=0;_
    _ area=(y2+y1)/2deltax/1000;
    * return area;*
    float rk4Integrate(int y4, int y3, int y2, int y1, float deltax){
    * float area=0;*
    area=((y4+2y3+2y2+y1)/6)deltax/1000;_
    _
    return area;_
    _
    }_
    _
    {_
    _ Serial.begin(115200);
    Serial.println("WM+ Tuning People Bot Control");_
    _
    Wire.begin();_
    _
    wmpOn(); //turn WM+ on*_
    * calibrateZeroes(); //calibrate zeroes*
    * delay(1000);*
* yawServo.attach(2);*
* pitchServo.attach(3);*
* pinMode(4, INPUT);*
void loop(){
* receiveData(); //receive data and calculate yaw pitch and roll*
* time=millis();*
* delta_t=(time-last_time);*
_ /* Runge-kutta 4th Order Integration /_
yaw_deg+=rk4Integrate(yaw, last_yaw[0], last_yaw[1], last_yaw[2], delta_t);
pitch_deg+=rk4Integrate(pitch, last_pitch[0], last_pitch[1], last_pitch[2], delta_t);
roll_deg+=rk4Integrate(roll, last_roll[0], last_roll[1], last_roll[2], delta_t);
last_yaw[2]=last_yaw[1];
last_pitch[2]=last_pitch[1];
last_roll[2]=last_roll[1];
last_yaw[1]=last_yaw[0];
last_pitch[1]=last_pitch[0];
last_roll[1]=last_roll[0];
last_yaw[0]=yaw;
last_pitch[0]=pitch;
last_roll[0]=roll;
last_time=time;
_ / Runge-kutta 4th Order Integration */_
* if (digitalRead(4) == 1)*
* last_yaw[2]=0;
last_pitch[2]=0;
last_roll[2]=0;
last_yaw[1]=0;
last_pitch[1]=0;
last_roll[1]=0;
last_yaw[0]=0;
last_pitch[0]=0;
last_roll[0]=0;
_
yaw = 0;_
_
pitch = 0;_
_
roll = 0;_
yaw_deg = 0;
pitch_deg = 0;
roll_deg = 0;
_
}_
yawServoVal = map(yaw_deg, -90, 90, 0, 179);
_
if (yawServoVal < 0){yawServoVal = 0;};_
_
if (yawServoVal > 179){yawServoVal = 179;};_
_
yawServo.write(yawServoVal);*_
* pitchServoVal = map(pitch_deg, -90, 90, 0, 179);
_
if (pitchServoVal < 60){pitchServoVal = 60;};_
_
if (pitchServoVal > 179){pitchServoVal = 179;};_
_
pitchServo.write(pitchServoVal);*_
Serial<<yaw_deg<<"\t"<<pitch_deg<<"\t"<<roll_deg<<"\n";
* delay(10);*
[/quote]
Didn't think you could use delay in setup?
I just think it's a function that runs once in the beginning of the program.
Sure you can, however if the purpose is to allow things to settle down before starting then it would be better if it's the very first statement in the setup() portion of your sketch.
Lefty
I tried adding a 10 second delay at the beginning of the program.
Did not make a difference.
There seem to be uninitialized variables in the sketch? - If so they will be sensitive to the (random) contents of RAM at startup - perhaps the sketch's setup() routine puts them in a saner state that allows it to run properly/better on the next reset. (Reset won't touch RAM I believe).
If you have a variable that can be read before it is first written, this is usually a problem. In particular you have floats that are not initialized so they might be NaN's at startup - NaN's are contagious.
Thanks Mark.
Updated my code to initialize all my variables before first run.
No difference.
Wierd Shit.
#include <Wire.h>
#include <Servo.h>
Servo yawServo;
Servo pitchServo;
int yawServoVal = 90;
int pitchServoVal = 90;
byte data[6] = {0,0,0,0,0,0}; //six data bytes
int yaw, pitch, roll = 0; //three axes
int yaw0, pitch0, roll0 = 0; //calibration zeroes
int time, last_time = 0;
float delta_t = 0;
int last_yaw[3] = {0, 0, 0};
int last_pitch[3] = {0,0,0};
int last_roll[3] = {0,0,0};
float yaw_deg, pitch_deg, roll_deg = 0;
void wmpOn(){
Wire.send(0x04);
void wmpSendZero(){
wmpSendZero();
    void receiveData(){
    _
    }_
    _
    }_
    _
    float area=0;_
    _ area=((y4+2y3+2y2+y1)/6)deltax/1000;_
    _
    return area;
    _
    * Wire.begin();*
    * wmpOn(); //turn WM+ on*
    * delay(1000);*
void loop(){
* time=millis();*
last_yaw[0]=yaw;
last_roll[0]=roll;
last_time=time;
* last_yaw[2]=0;
last_pitch[2]=0;
last_roll[2]=0;
last_yaw[1]=0;
last_pitch[1]=0;
last_roll[1]=0;
last_yaw[0]=0;
last_pitch[0]=0;
last_roll[0]=0;
_
yaw = 0;_
_
pitch = 0;_
_
roll = 0;_
yaw_deg = 0;
pitch_deg = 0;
roll_deg = 0;
_
}_
_
_
_
_
_
_
* delay(10);*
[/quote]
Can you use "Code" instead of "quote" when posting code, please?
My scroll finger is feeling poorly.
I'm sorry. I was using "copy for discourse" in the Arduino IDE. I thought that was how it was to be done.
Anyone, any ideas so far?
Why does my Arduino act different on reset then when I power cycle it?
First off, let me say I know nothing about the Wii, Nunchuck, Motion+ or how to make it work with the Arduino (I do realize that the Motion+ and Nunchuck are separate, but work together) - with that said, I found this page:
http://www.windmeadow.com/node/42
I noticed that it's init function is different from your's; maybe the motion+ has a different init? Or do you have to do the init for the nunchuck and a different one for the motion+?
I am probably waaay off-base here...
:slight_smile:
[edit]Hmm - looking at this page:
seems to indicate that your code matches up - unless this is your site! :D[/edit]
[edit]I guess what I am getting at is that maybe on cold-boot, something gets sent that partially inits the wiimotion, but not fully, then a reset throws some new values to finish the init...?
:-?[/edit]
Hey Crosh,
Yeah, my code is 90% that of Nuckles.
Picked it up in a topic here.
I'm still baffeled about the whole thing.
Is there any information available about what exactly the Arduino does on a cold boot vs a reset?
