Cold Cathode (CCFL), Mosfets And Arduino Nano
Hi guys
I am a total nub at the arduino. I practically know the basics of the Arduino. I am currently learning C+.
Ok so How does the Mosfet work? Does it simply expand the amount of current going through it as well as the signal?
I need a schematic to drive the CCFL (Through the INVERTER) So could someone possible make one?
Thanks
Basically the resistance between the drain and source is controlled by the voltage on the gate. So once you take the gate higher than the turn on voltage (this varies with different types of FET) the resistance will be small, typically less that half an ohm (0.5R).
You will have to be a bit more specific about what CCFL you are using as drive requirements are different on different devices.
