collect2: error: ld returned 1 exit status exit status 1 Erreur de compilation
I'm at my first project on arduino and I can't figure out what the problem is with my coding. It says
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
Ceci est mon premier projet sur arduino et je ne trouve pas mon erreur de codage.
Here's my code / Voici mon code:
void loop(){
int pinUn = 1;
int pinDeux =2;
pinMode (pinUn , OUTPUT);
pinMode (pinDeux , INPUT);
if (pinDeux == HIGH){
analogWrite (pinUn , HIGH) ;
delay (500);
analogWrite (pinUn , LOW);
else{
for(int pwr=0 ; pwr < 200 ; pwr ++ ){
analogWrite(pinUn , pwr);
(deleted)
I added up a setup, now Arduino do not point any error but when i upload it it does not work, the led stays off
void setup(){
int pinUn = 1;
int pinDeux =2;
void loop(){
int pinUn = 1;
int pinDeux =2;
delay (500);
else{
hello
ICI
int pinUn = A0;//attention, ce n'est plus 1 mais A0
  int pinDeux =2;
void loop(){
    delay (500);
/*I've try your code and it still dont work, i tried to fix it again... still wont work. Here's where i'm at:
J'ai essayé ton code, ça ne fonctionne toujours pas, j'ai essayer de résoudre le problème... voici ou j'en suis:
int pinUn = A0;
int pinDeux =2;
void loop(){
delay (500);
for(int pwr=0 ; pwr < 1000 ; pwr ++ )
if(pwr >= 1000){
int pwr = 0;
