Collision Avoidance Robot making beepy noises?
Hello all,
So here I have my pretty basic collision avoidance robot:
#include <Servo.h>
#include<AFMotor.h>
//Declare Servos
Servo scanservo;     //Ping Sensor Servo
const int motor1 = 12;
const int motor2 = 9;
const int steer1 = 13;
const int steer2 = 8;
const int a = 800;
const int turntime = 500;  //Number of milliseconds to turn when turning
const int pingPin = 4;     //Pin that the Ping sensor is attached to.
const int echoPin = 5;     //Pin that the Ping sensor is attached to.
const int scanservopin = 7;   // Pin number for scan servo
const int distancelimit = 10;   //If something gets this many inched from
                                 // the robot it stops and looks for where to go.
//Setup function. Runs once when Arduino is turned on or restarted
  Serial.begin (9600);
  scanservo.attach(scanservopin); // Attach the scan servo
  pinMode(motor1, OUTPUT);
  pinMode(motor2, OUTPUT);
  pinMode(steer1, OUTPUT);
  pinMode(steer2, OUTPUT);
  //Variable inicialization
  digitalWrite(motor1,LOW);
  digitalWrite(motor2,LOW);
  digitalWrite(steer1,LOW);
  digitalWrite(steer2,LOW);
  delay(2000);        // wait two seconds
void loop(){
  go();  // if nothing is wrong the go forward using go() function below.
  int distance = ping(); // us the ping() function to see if anything is ahead.
    if (distance < distancelimit){
    stopmotors(); // If something is ahead, stop the motors.
    char turndirection = scan(); //Decide which direction to turn.
    switch (turndirection){
      case 'l':
        turnleft(turntime);
      case 'r':
        turnright(turntime);
      case 'b':
        backward(1500);
        turnright(1500);
        stopmotors();
      case 's':
        forward(turntime);
int ping(){
  long distance, duration;
  //Send Pulse
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  //Read Echo
  pinMode(echoPin, INPUT);
  duration = pulseIn(echoPin, HIGH);
    distance=(duration/2)*0.0341;
  Serial.print("Ping:  ");
  Serial.println(distance);
void go(){
  digitalWrite(12, HIGH);
  digitalWrite(9, LOW);
  digitalWrite(3, HIGH);
  delay(600);
void turnleft(int t){
  digitalWrite (13, HIGH);
  digitalWrite (8, LOW);
  digitalWrite (11, HIGH);
  delay(t);
void turnright(int t){
  digitalWrite (13, LOW);
  delay(t);
void forward(int t){
  delay(600);
void backward(int t){
  digitalWrite (9, LOW);
  digitalWrite (12, LOW);
  delay(t);
void stopmotors(){
  digitalWrite (9, HIGH);
  digitalWrite (8, HIGH);
  digitalWrite (3, HIGH);
  delay(600);
char scan(){
  int leftscanval, centerscanval, rightscanval;
  char choice;
  //Look left
  scanservo.write(30);
  delay(300);
  leftscanval = ping();
  //Look right
  scanservo.write(150);
  rightscanval = ping();
  //center scan servo
  scanservo.write(88);
  if (leftscanval>rightscanval && leftscanval>centerscanval){
    choice = 'l';
  else if (rightscanval>leftscanval && rightscanval>centerscanval){
    choice = 'r';
  else if (rightscanval<30 && leftscanval<30 && centerscanval<30){
    choice = 'b';
  else{
    choice = 's';
  Serial.print("Choice:  ");
  Serial.println(choice);
  return choice;
Works alright....the problem is, it moves too fast...
So when I try and set the set using " analogWrite(3, 123); in place of digitalWrite(3,HIGH); for example it make beeping noises that do not sound very healthy .
I guess I'm not using PWM correctly. Can anyone see the error?
Please help my poor robot become the best that it can be :smiley:
Do you think it is possible to answer this question without knowing what hardware you're using and how it is connected?
Oh right yeah, sorry my bad!
I'm using an UNO and motor shield,
I've hacked a remote control car...and then outputs from the motor shield connect to the corresponding motor/servo
Ummmm....and, anything else you would like to know?
Where is the beeping coming from?
Since it seems to be related somehow to the way you're driving the motor, I suggest you post a drawing/diagram showing the circuits that power and control the motors.
Can you upload a video of those beeps ?
I copied the code and used it with my Sharp A02 distance sensor. In your char scan() routine you never took a centerscanval reading using the ping function. I got your code to work. But I am using the Zumo motor shield and motor library to run motors on pins 9 and 10. I am a newbie thanks.
