Color Sensing with TCS3200, Need Help with Code & Understanding
The outputs constantly change because: 1) Different colors & objects being sensed 2) Different lighting and such.
So, I worry that statically assigning them would make it so only these colored objects or cards would be scannable. (And I'd probably have to go scanning pretty much everything I want to "sense" with the TCS3200 color sensor, to log it in the code.)
Is there no way to "dynamically" do it? Like tell the RGB LED to display the color based upon the information that's streamed into terminal, dynamically?
If this doesn't pose a problem, because most colors will be detected and outputted in a similar way to eachother (like a white card would show a white LED and a white wall would show a white LED), then could you provide me the code necessary to do that?
I feel lost, hah! Thank you again, you've been super helpful. I gave you karma :slight_smile:
