Hi All
Interesting topic & conversation:
Here is my current take on things ... code still has issues
Observe and report an object's visible color spectrum via a TCS3200 light-to-frequency converter
Materials Schedule
Arduino Uno - 1 each
https://store.arduino.cc/usa/arduino-uno-rev3
DF Robot Gravity I/O Shield - 1 each
https://www.dfrobot.com/product-1009.html
DF Robot Color Sensor - 1 each
https://www.dfrobot.com/product-540.html
A-B Cable - 1 each
https://www.staples.com/usb+ab+cable/directory_usb+ab+cable
Wire Bundles - 7 female/female wires
https://www.adafruit.com/product/266
Assembly
1.Connect A-B cable to arduino and laptop and upload sketch
2.Connect aurduino and shield
3.Connect color sensor to I/O shield digital pins 4, 5, 6, 7, 8 and VCC and GND with (7) female/female wires
(D) Digital D4 Green S0
(D) Digital D5 Black S1
(D) Digital D6 Red S2
(D) Digital D7 White S3
(D) Digital D8 Yellow OUT
(+) Voltage VCC Red VCC
(-) Ground GND Black GND
4.Open serial monitor to view sensor readings at 9600 baud
Sensor assumptions (Texas Advanced Optoelectronic Solutions TCS3200)
Max output frequency = 600 kHz (1 kHz = 0.001 MHz, 600 kHz = 0.6 MHz)
Max data acquisition rate = 1 datapoint/microsecond (1,000 microseconds = 1 millisecond)
8 bit Timer on Atmel AVR - FreqCount Library, for measuring frequencies - Paul Stoffregen <paul@pjrc.com>
* 1ms 2ms 4ms 8ms
2 MHz 8x250 32x125 64x125 128x125
1 MHz 8x125 8x250 32x125 64x125
Sensor power settings
Clear: S2 High S3 Low
Red: S2 Low S3 Low
Blue: S2 Low S3 High
Green: S2 High S3 High
RGB Model - How to Mechatronics
Clear: Red ? Green ? Blue ? Clear ?
Red: Red 25 Green 72 Blue 255 Clear 0 Hex 1946FF https://convertingcolors.com/rgb-color-25_70_255.html#about
Green: Red 30 Green 90 Blue 255 Clear 0 Hex 1E5AFF https://convertingcolors.com/rgb-color-30_90_255.html#about
Blue: Red 25 Green 70 Blue 255 Clear 0 Hex 1946FF https://convertingcolors.com/rgb-color-25_70_255.html#about
RGB Model - DF Robot
Clear: Red 118 Green 106 Blue 111 Clear 0 Hex 766A6F https://convertingcolors.com/rgb-color-118_106_111.html#about
Red: Red 92 Green 33 Blue 35 Clear 0 Hex 5C2123 https://convertingcolors.com/rgb-color-92_33_35.html#about
Green: Red 112 Green 78 Blue 57 Clear 0 Hex 704E70 https://convertingcolors.com/rgb-color-112_78_112.html
Blue: Red 38 Green 33 Blue 45 Clear 0 Hex 26212D https://convertingcolors.com/rgb-color-38_33_45.html#about
RGB Model - surfnm
Clear: Red 255 Green 255 Blue 255 Clear 0 Hex FFFFFF https://convertingcolors.com/rgb-color-255_255_255.html
Red: Red 255 Green 0 Blue 0 Clear 0 Hex FF0000 https://convertingcolors.com/rgb-color-255_0_0.html
Green: Red 0 Green 255 Blue 0 Clear 0 Hex 00FF00 https://convertingcolors.com/rgb-color-0_255_0.html
Blue: Red 0 Green 0 Blue 255 Clear 0 Hex 0000FF https://convertingcolors.com/rgb-color-0_0_255.html
Engineering
Created by Dejan Nedelkovski
https://howtomechatronics.com/tutorials/arduino/arduino-color-sensing-tutorial-tcs230-tcs3200-color-sensor/
Created by DF Robot
https://www.dfrobot.com/wiki/index.php/TCS3200_Color_Sensor_(SKU:SEN0101)
Team Arduino Forum
Color Sensing with TCS3200, Need Help with Code & Understanding
https://forum.arduino.cc/index.php?topic=549632.0
Problem with Arduino Uno Color sensor TC3200
https://forum.arduino.cc/index.php?topic=469940.0
Modified by surfnm
//=== Global constants and variables ======
// TCS3200 light-to-frequency converter wiring
#define S0 4
#define S1 5
#define S2 6
#define S3 7
#define sensorOut 8
int frequency = 0; // int (16 bit = 2 byte value = range of -32,768 to 32,767)
// === Setup code, runs once =========================
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut, INPUT);
// Setting frequency-scaling to 20%
digitalWrite(S0,HIGH);
digitalWrite(S1,LOW);
Serial.begin(9600); // use the serial port to print out the resultant data
// === Main code, runs/loops repeatedly ==============
// Setting Red filtered photodiodes to be read
digitalWrite(S2,LOW);
digitalWrite(S3,LOW);
// Reading the output frequency
frequency = pulseIn(sensorOut, LOW);
// Remap the value of the Frequency to the RGB Model
// Syntax - map(value, fromLow, fromHigh, toLow, toHigh)
// Frequency Model fromLow = 0, Frequency Model fromHigh = 600
// RGB Model toLow = 0, RGB Model toHigh = 255
frequency = map(frequency, 0,600,0,255);
// Printing the value on the serial monitor
Serial.print("R= ");//printing name
Serial.print(frequency);//printing RED color frequency
Serial.print(" ");
delay(100);
// Setting Green filtered photodiodes to be read
digitalWrite(S2,HIGH);
digitalWrite(S3,HIGH);
Serial.print("G= ");//printing name
Serial.print(frequency);//printing GREEN color frequency
Serial.print(" ");
delay(100);
// Setting Blue filtered photodiodes to be read
Serial.print("B= ");//printing name
Serial.print(frequency);//printing BLUE color frequency
Serial.println(" ");
delay(100);
