Hi so I'm trying to program a robot that uses a color sensor and moves. I tried putting together two programs (one for the color sensor and one for the motors) that work separately but but it didn't work.
I got this error:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Uno"
program_1:64:13: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
program_1:65:15: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite(9, LOW); //Disengage the Brake for Channel A
program_1:66:14: error: expected constructor, destructor, or type conversion before '(' token
analogWrite(3, 225); //Spins the motor on Channel A at full speed
program_1:69:16: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite(13, LOW); //Establishes forward direction of Channel A
program_1:70:15: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite(8, LOW); //Disengage the Brake for Channel A
program_1:71:15: error: expected constructor, destructor, or type conversion before '(' token
analogWrite (11, 225); //Spins the motor on Channel A at full speed
program_1:72:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
I am using an adafruit temperature sensor and two DC motors connected to the motor shield.
My code is:
#include <Wire.h>
#include "Adafruit_TCS34725.h"
/* Example code for the Adafruit TCS34725 breakout library */
/* Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3.3V DC
Connect GROUND to common ground */
/* Initialise with default values (int time = 2.4ms, gain = 1x) */
// Adafruit_TCS34725 tcs = Adafruit_TCS34725();
/* Initialise with specific int time and gain values */
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_700MS, TCS34725_GAIN_1X);
// color sensor
if (tcs.begin()) {
Serial.println("Found sensor");
Serial.println("No TCS34725 found ... check your connections");
while (1);
//MOTOR A
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
//MOTOR B
pinMode(13, OUTPUT); //Initiates Motor Channel A pin
pinMode(8, OUTPUT); //Initiates Brake Channel A pin
//color sensor
uint16_t r, g, b, c, colorTemp, lux;
tcs.getRawData(&r, &g, &b, &c);
// colorTemp = tcs.calculateColorTemperature(r, g, b);
colorTemp = tcs.calculateColorTemperature_dn40(r, g, b, c);
lux = tcs.calculateLux(r, g, b);
Serial.print("Color Temp: "); Serial.print(colorTemp, DEC); Serial.print(" K - ");
Serial.print("Lux: "); Serial.print(lux, DEC); Serial.print(" - ");
Serial.print("R: "); Serial.print(r, DEC); Serial.print(" ");
Serial.print("G: "); Serial.print(g, DEC); Serial.print(" ");
Serial.print("B: "); Serial.print(b, DEC); Serial.print(" ");
Serial.print("C: "); Serial.print(c, DEC); Serial.print(" ");
Serial.println(" ");
// Motor A backward
//Motor B forwards
