Color sensor TO5
I´ve bought a color sensor, https://www.elfa.se/elfa3~se_sv/elfa/init.do?item=75-444-13&toc=20402, and I´m now trying to connect it to my Arduino Duemilanova. I´m feeding it with 5V and I understand I somehow need to transform the photo current into a suitable voltage to be able to use it. I can't find any data about the size of the current... What is the best way to convert the current to voltage?
Where?
Please don't. Hope you haven't damaged it.
Simplest is making it flow through a resistor.
However page 7 of the data sheet shows it being fed into three op amps. I would go with that.
5V into the common cathode, should I stop doing that?
Yes. the data sheet says:-
Maximum Ratings
Reverse voltage 2.5V
Ok, no I notcie I´ve actually got another product than I ordered. I´ve got TO5 instead of TO39. The data sheet that came with the sensor says "Reverse Voltage VR 0...5V". It still seems to work ok.
Will look into op amps.
Thanks!
