Color sorting machine
Hello,
I am trying to make colour sorting machine as showed here Arduino Color Sorter Project - YouTube, however I can't get my bottom (sensor) motor to move.
Motor itself is working properly, once I reconnect them separately - each one works, when together only non sensor one.
I connect both servo motors directly to arduino and supply it from laptop's usb - no capacitors or anything used.
Does anyone has any hint here? Thanks.
Please post the code you use.
Nobody will be able to answer your question without it.
Code is below, however I don't think it is code-issue since every component works on its own running same code parts.
/* Arduino Project - Color Sorting Machine
#include <Servo.h>
#define S0 2
#define S1 3
#define S2 4
#define S3 5
#define sensorOut 6
Servo topServo;
Servo bottomServo;
int frequency = 0;
int color=0;
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut, INPUT);
// Setting frequency-scaling to 20%
digitalWrite(S0, HIGH);
digitalWrite(S1, LOW);
topServo.attach(7);
bottomServo.attach(8);
topServo.write(115);
for(int i = 115; i > 65; i--) {
topServo.write(i);
delay(2);
color = readColor();
delay(10);
switch (color) {
case 1:
bottomServo.write(50);
case 2:
bottomServo.write(75);
case 3:
bottomServo.write(100);
case 4:
bottomServo.write(125);
case 5:
bottomServo.write(150);
case 6:
bottomServo.write(175);
case 0:
delay(300);
for(int i = 65; i > 29; i--) {
topServo.write(i);
delay(2);
delay(200);
for(int i = 29; i < 115; i++) {
topServo.write(i);
delay(2);
color=0;
// Custom Function - readColor()
int readColor() {
// Setting red filtered photodiodes to be read
digitalWrite(S2, LOW);
digitalWrite(S3, LOW);
// Reading the output frequency
frequency = pulseIn(sensorOut, LOW);
int R = frequency;
// Printing the value on the serial monitor
Serial.print("R= ");//printing name
Serial.print(frequency);//printing RED color frequency
Serial.print(" ");
delay(50);
// Setting Green filtered photodiodes to be read
digitalWrite(S2, HIGH);
digitalWrite(S3, HIGH);
int G = frequency;
Serial.print("G= ");//printing name
Serial.print(" ");
delay(50);
// Setting Blue filtered photodiodes to be read
int B = frequency;
Serial.print("B= ");//printing name
Serial.println(" ");
delay(50);
if(R<45 & R>32 & G<65 & G>55){
color = 1; // Red
if(G<55 & G>43 & B<47 &B>35){
color = 2; // Orange
if(R<53 & R>40 & G<53 & G>40){
color = 3; // Green
if(R<38 & R>24 & G<44 & G>30){
color = 4; // Yellow
if(R<56 & R>46 & G<65 & G>55){
color = 5; // Brown
if (G<58 & G>45 & B<40 &B>26){
color = 6; // Blue
return color;
Please put your code in tags to make it more readable.
I found this thread which might help you: Using Multiple Servos with Arduino - Robotics - Arduino Forum .
Servos can draw up to an amp of current. They will need a separate power supply: you can't connect even one to the Arduino's 5V pin and expect the system to work.
Hello,
Thanks. I supposed that as well, but a bit short on time so to check with experts :slight_smile:
if(R<45 & R>32 & G<65 & G>55) You should be using "&&" here.
