I’m kind of lost in the forum, so I ask you to help with the error of this sketch:
* Colorduino Christmas Ornament
* @author Raj Madhuram, 2014
#include "fonts.c"
#include <Colorduino.h>
int mode = 0;
// For scroller.
int stepCounter = 0;
int scrollCounter = 0;
int currentGreeting = 0;
int const MAX_STRINGS = 4;
const char *greetings[MAX_STRINGS] = {
"* Merry Christmas! Drop your presents below. *",
"For unto us a Child is born - Is 9:6 ",
"Joy to the world ",
"Emmanuel, God with us "
// For color changing star.
typedef struct Color {
int r;
int g;
int b;
Color current;
Color target;
int colorCounter = 0;
int const MAX_STEPS = 10;
char buffer[8][8];
Nome: ColorFill
Função: Preenche o frame com uma cor
Parâmetro: R: the value of RED. Range:RED 0~255
G: the value of GREEN. Range:RED 0~255
B: the value of BLUE. Range:RED 0~255
void ColorFill(unsigned char R,unsigned char G,unsigned char B)
PixelRGB *p = Colorduino.GetPixel(0,0);
for (unsigned char y=0;y<ColorduinoScreenWidth;y++) {
for(unsigned char x=0;x<ColorduinoScreenHeight;x++) {
p->r = R;
p->g = G;
p->b = B;
p++;
Colorduino.Init();
unsigned char whiteBalVal[3] = {36,63,63}; // para Matriz redonda 6x6cm da LEDSEE
Colorduino.SetWhiteBal(whiteBalVal);
ColorFill(0, 0, 0);
for (int i=0; i<8; i++) {
for (int j=0; j<8; j++) {
buffer[i][j] = 0;
* Rolagem
void scroll_drawPage() {
ColorFill(0, 0, 0);
int r, g, b;
if (j < 4) {
r = 240; g = 0; b = 0;
r = 0; g = 240; b = 0;
if (buffer[i][j] == 1) {
Colorduino.SetPixel(7-i, j, r, g, b);
Colorduino.FlipPage();
void scroll_drawText(int count) {
int fontIndex = (int) count / 6;
unsigned char c = greetings[currentGreeting][fontIndex];
for (int i=0; i<7; i++) {
buffer[i][j] = buffer[i+1][j];
int idx = count % 6;
unsigned char code = 0;
if (idx != 5) {
code = font[c*5 + idx];
buffer[7][j] = code % 2;
code = code >> 1;
scroll_drawPage();
* Trocador de cores
void cc_fill() {
float alpha = (float) colorCounter / MAX_STEPS;
int r = floor((1-alpha)*current.r + alpha*target.r);
int g = floor((1-alpha)*current.g + alpha*target.g);
int b = floor((1-alpha)*current.b + alpha*target.b);
// máscara com um asterisco.
unsigned char mask[8] = {0x00, 0x99, 0x5a, 0x3c, 0xff, 0x3c, 0x5a, 0x99};
int row = mask[i];
if (row % 2 == 1) {
p->r = r; p->g = g; p->b = b;
p->r = 0; p->g = 0; p->b = 0;
row = row >> 1;
p++;
if (mode == 0) {
colorCounter++;
cc_fill();
if (colorCounter == MAX_STEPS) {
colorCounter = 0;
stepCounter++;
if (stepCounter == 20) {
mode = 1;
stepCounter = 0;
current.r = target.r;
current.g = target.g;
current.b = target.b;
target.r = random(256);
target.g = random(256);
target.b = random(256);
delay(200);
} else if (mode == 1) {
scroll_drawText(scrollCounter);
scrollCounter++;
if (scrollCounter >= strlen(greetings[currentGreeting]) * 6) {
scrollCounter = 0;
currentGreeting = random(MAX_STRINGS);
stepCounter++;
if (stepCounter == 2) {
mode = 0;
stepCounter = 0;
delay(120);
Nota: I want to emphasize that the code is written by: Raj Madhuram, 2014
The error is this: ‘PixelRGB’ was not declared in this scope
I’m using Arduino 1.8.5
Thank you all
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Greetings everyone
I’d like some help with the attached code:
Here: Colorduino Christmas Ornament - YouTube
I anticipate my thanks
Moderator edit: Posts merged
christmas.ino (3.79 KB)
fonts.c (8.34 KB)
