Colors using Adafruit_ST7735.h
I'm trying to fill in the gaps for colors. I've started with trying to save ORANGE. I see in Adafruit_ST7735.h ,for lcd display, colors are defined by 0xABCD. However when I look up colors online I see a 6 digit hex 0xABCDEF. What am I missing? How do I define colors using only 4 digit hex, like as seen in Adafruit_ST7735.h file?
// Color definitions
#define	ST7735_BLACK   0x0000
#define	ST7735_BLUE    0xF800
#define	ST7735_RED     0x001F
#define	ST7735_ORANGE  0x00AA  //TEST CREATING COLOR
#define	ST7735_GREEN   0x07E0
#define ST7735_CYAN    0xFFE0
#define ST7735_MAGENTA 0xF81F
#define ST7735_YELLOW  0x07FF
#define ST7735_WHITE   0xFFFF
There is probably a color565(r, g, b) method.
You can write an equivalent macro.
David.
david_prentice:
David.
I don't understand exactly what you're proposing I do. I need step by step instructions.
You can look up standard 24-bit colours. i.e. 8-bits for RED, 8-bits for GREEN, ...
You convert them to to 16-bits i.e. 5-bits for RED, 6-bits for GREEN, 5-bits for BLUE:
#define RGB(r, g, b) (((r&0xF8)<<8)|((g&0xFC)<<3)|(b>>3))
#define GREY      RGB(127, 127, 127)
#define DARKGREY  RGB(64, 64, 64)
#define TURQUOISE RGB(0, 128, 128)
#define PINK      RGB(255, 128, 192)
#define OLIVE     RGB(128, 128, 0)
#define PURPLE    RGB(128, 0, 128)
#define AZURE     RGB(0, 128, 255)
#define ORANGE    RGB(255,128,64)
Since this is a common thing to do in TFT programs, the libraries tend to have suitable methods:
e.g. Adafruit_ST7735.h
  uint16_t Color565(uint8_t r, uint8_t g, uint8_t b);
e.g. MCUFRIEND_kbv.h
	uint16_t color565(uint8_t r, uint8_t g, uint8_t b) { return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | ((b & 0xF8) >> 3); }
David.
I tested the 1st block of code and found that it's not RGB, but BGR. Blue and Green are opposite. Maybe I should reinstall the library. I haven't tried color565() yet.
BGR is a single bit to change. Your library proably has a configuration option.
Of course you could change the macro but the whole world expects RED to be 0xF800.
