COM 10 can't write (I think?)
Ok, followed an online guide to a RFID kit, just the basic RFID board, LEDs, microcontrol, and a motor. Code provided wasn't quite working, messed with it a bit, click upload (after verifying, with not errors) and I get
avrdude: ser_open(): can't set com-state for "\.\COM10"
An error occurred while uploading the sketch
Serial monitor was set wrong, so I changed it to what the code had, which was 9600, but then I get this:
Error while setting serial port parameters: 9,600 N 8 1
So... I am actually kind of confused. I've incuded the code I'm using, incase that is required. In addition, I know this isn't the proper place to give feedback about my code, however I personnally am not against a little pointing-out-a-flaw Thank you, have a nice day!
Guide I followed: http://www.instructables.com/id/RFID-Security-Access-System/
#include <Servo.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
#define LED_G 5 //define green LED pin
#define LED_R 4 //define red LED
#define BUZZER 2 //buzzer pin
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Servo myServo; //define servo name
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate
myServo.attach(3); //servo pin
myServo.write(0); //servo start position
pinMode(LED_G, OUTPUT);
pinMode(LED_R, OUTPUT);
pinMode(BUZZER, OUTPUT);
noTone(BUZZER);
Serial.println("Put your card to the reader...");
} void loop() { // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) { return; } // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) { return; } //Show UID on serial monitor
  Serial.print("UID tag :"); String content= ""; byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++) { Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
  Serial.print(mfrc522.uid.uidByte[i], HEX);
  content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
  content.concat(String(mfrc522.uid.uidByte[i], HEX)); } Serial.println(); Serial.print("Message : ");
  content.toUpperCase(); if (content.substring(1) == "XX XX XX XX") //change here the UID of the card/cards that you want to give access
  { Serial.println("Authorized access"); Serial.println(); delay(500); digitalWrite(LED_G, HIGH); tone(BUZZER, 500); delay(300); noTone(BUZZER); myServo.write(180); delay(5000); myServo.write(0); digitalWrite(LED_G, LOW); } else { Serial.println(" Access denied"); digitalWrite(LED_R, HIGH); tone(BUZZER, 300); delay(1000); digitalWrite(LED_R, LOW); noTone(BUZZER); } }
