Hello people.
I have a problem with the Arduino UNO R3. Maybe you can guide me. I was trying to control a servo motor when it started. I can no longer upload sketches.
The sketch is compiled starts to load (the RX led flashes a couple of times) and then hangs (the TX led does not light up). If I press RESET, nothing happens (L Led does not flash, stays on all the time). After a long time the error below appears in the IDE:
The sketch uses 444 bytes (1%) of storage space for programs. The maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. The maximum is 2048 bytes.
avrdude: stk500_recv (): programmer is not responding
avrdude: stk500_getsync () attempt 1 of 10: not in sync: resp = 0xbc
avrdude: stk500_getsync () attempt 2 of 10: not in sync: resp = 0xbc
avrdude: stk500_getsync () attempt 9 of 10: not in sync: resp = 0xbc
avrdude: stk500_getsync () attempt 10 of 10: not in sync: resp = 0xbc
Problem loading to the card. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
When trying to write the Bootloader through the IDE I got the message: "Error writing the bootloader."
I'm a beginner with Arduino. I looked for help on Arduino.cc (troubleshooting), but none of the tips helped to solve the problem. Do you have any idea what's going on?
