com port and loops
Hi all, I am making a 3x3 stage blinder and want to make it do some patterns , the electrical part is all tested and works great (triacs with optocapler to turn the 220v bulbs via the 5v arduino outs) , now I have problems with the code:
  1. It will be controlled via a computer COM port, I have made this work, but only one letter sent= one pin goes on or off, I want to know how to make it go to a loop when it receives something from the computer, for example if I send letter b it will go to a loop that blinks all the bulbs? This is the code so instead of digital write(9,HIGH) some goto or something similar to go to a loop ?
void setup ()
  pinMode(9,OUTPUT);
  digitalWrite(9,LOW);
  if(Serial.available() > 0 )
    char letter = Serial.read();
    if(letter == '1')
    {digitalWrite(9,HIGH);
    else if(letter == '0')
      digitalWrite(9,LOW) ;
  1. how to make the loop repeat itself until it receives something else and how to stop it in the middle of execution ? So can the loop look like turn pins pins from 1 to 5 in a sequence on and off with delays between, repeat that until you get some other signal , and if you get the signal before you get to pin 3 stop, and go to some other loop ?
sorry if these are some trivial questions, but I am fairly new to this and cant figure this out
Put the stuff you want to happen into a function and set a variable that tells the function to work (or not) instead of (or as well as) digitalWrite() when the character is received. Something like this:
[code] if(letter == '1')
     startFlashing = true;
     // etc
myFlashingFuntion() {
   if (startFlashing == true) {
       // do some clever stuff
And the code in loop() should be something like this
  getDataFromPC();  // the code you now have to get the data including setting a variable as above
  myFlashingFunction();
And make sure that the code in the myFlashingFunction() does not block anything. Use millis() for timing. See the demo several things at a time.
...R
