COM ports dead
I feel like an idiot.
I havent used IDE for a while and now the COM port is greyed out. I had realTerm also installed, it complained of a registry issue (didn't do that before) when it tried to scan for com ports. Im using Win8 and I recently replaced the power supply in it.
The USB port works, I tried the one I had a webcam streaming on.
I tried Device manager and I don't see anything pop up.. I am trying it with ESP8266s, tried two....
OK... an Uno shows up.
Nope. It's just the ESP boards. I'll use the Uno!
I think your issue is resolved as you can see the UNO board ports under the Arduino IDE.
//Arduino
For the ESP8266 boards:
Make sure the USB cable is completely plugged in to both the Arduino board and the PC.
You may have a damaged/defective or charge-only USB cable. Try a different cable.
Maybe cable!
pert:
THANKS
A
MILLION.
It WAS cable.
Pert saves the day again!!!!
I'm glad to hear it's working now.
@mattlogue
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
With so many posts you should know better !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
