COM4 port not appearing
I am using Aruino UNO R3. It was working fine. To modify code when I connected to Dell Inspiron 7548 Window 10. COM4 port is not appering. Serial Port 6 & 7 which are Bluetooth links are appearing.
I uninstalled the Arduino IDE and reinstalled. Board is lighting and working as per previous code.
I installed and updated drivers but same result. Checked Device Manager for Serial Port COM4. Unhide all devices.
I tried to get Board Information. Message is "Native Serial Port, can't obtain info".
I activated verbose but it is stuck during uploading below message is appearing.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
Please help.
Regards
Arduinos typically sit on different COM port with different PCs.
Yep even I had such an experience.
I changed my computer so on my old one it was COM3 but on my other computer it was COM4.
pankajsharma200:
...I activated verbose but it is stuck during uploading below message is appearing...
Then the device on that communication port is not an Arduino.
So what happens in Windows device manager when you connect the board? Any yellow triangles? I have a suspicion that you're using a clone and forgot to install the driver; else you might have blown up the USB-to-TTL chip.
