Hello can i get a help,i want to do maybe a similiar thing with this post, but want to compare two coordinates.New coordinates are compared with previous coordinates.If the result is > 10 meters (0.01 km) or more, and if gps module can acknowledge that the modul is move it wil send a message to my device.
btw im using arduino nano,sim 800l and gps neo6m.
@abrahm14
TOPIC SPLIT
PLEASE DO NOT HIJACK
Could you also take a few moments to Learn How To Use The Forum .
Other general help and troubleshooting advice can be found here.
Thank you
To compare distances between nearby sets of GPS coordinates, the equirectangular approximation works well.
See Calculate distance and bearing between two Latitude/Longitude points using haversine formula in JavaScript
Some of the GPS libraries include a function for calculating the great-circle distance between two positions. Check your library documentation.
im using TinyGPS++ library can u show me which one is it to use?
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample code demonstrates just about every built-in operation of TinyGPS++ (TinyGPSPlus).
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// For stats that happen every 5 seconds
unsigned long last = 0UL;
ss.begin(GPSBaud);
Serial.println(F("KitchenSink.ino"));
Serial.println(F("Demonstrating nearly every feature of TinyGPS++"));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
// Dispatch incoming characters
while (ss.available() > 0)
gps.encode(ss.read());
if (gps.location.isUpdated())
Serial.print(F("LOCATION Fix Age="));
Serial.print(gps.location.age());
Serial.print(F("ms Raw Lat="));
Serial.print(gps.location.rawLat().negative ? "-" : "+");
Serial.print(gps.location.rawLat().deg);
Serial.print("[+");
Serial.print(gps.location.rawLat().billionths);
Serial.print(F(" billionths], Raw Long="));
Serial.print(gps.location.rawLng().negative ? "-" : "+");
Serial.print(gps.location.rawLng().deg);
Serial.print("[+");
Serial.print(gps.location.rawLng().billionths);
Serial.print(F(" billionths], Lat="));
Serial.print(gps.location.lat(), 6);
Serial.print(F(" Long="));
Serial.println(gps.location.lng(), 6);
else if (gps.date.isUpdated())
Serial.print(F("DATE Fix Age="));
Serial.print(gps.date.age());
Serial.print(F("ms Raw="));
Serial.print(gps.date.value());
Serial.print(F(" Year="));
Serial.print(gps.date.year());
Serial.print(F(" Month="));
Serial.print(gps.date.month());
Serial.print(F(" Day="));
Serial.println(gps.date.day());
else if (gps.time.isUpdated())
Serial.print(F("TIME Fix Age="));
Serial.print(gps.time.age());
Serial.print(gps.time.value());
Serial.print(F(" Hour="));
Serial.print(gps.time.hour());
Serial.print(F(" Minute="));
Serial.print(gps.time.minute());
Serial.print(F(" Second="));
Serial.print(gps.time.second());
Serial.print(F(" Hundredths="));
Serial.println(gps.time.centisecond());
else if (gps.speed.isUpdated())
Serial.print(F("SPEED Fix Age="));
Serial.print(gps.speed.age());
Serial.print(gps.speed.value());
Serial.print(F(" Knots="));
Serial.print(gps.speed.knots());
Serial.print(F(" MPH="));
Serial.print(gps.speed.mph());
Serial.print(F(" m/s="));
Serial.print(gps.speed.mps());
Serial.print(F(" km/h="));
Serial.println(gps.speed.kmph());
else if (gps.course.isUpdated())
Serial.print(F("COURSE Fix Age="));
Serial.print(gps.course.age());
Serial.print(gps.course.value());
Serial.print(F(" Deg="));
Serial.println(gps.course.deg());
else if (gps.altitude.isUpdated())
Serial.print(F("ALTITUDE Fix Age="));
Serial.print(gps.altitude.age());
Serial.print(gps.altitude.value());
Serial.print(F(" Meters="));
Serial.print(gps.altitude.meters());
Serial.print(F(" Miles="));
Serial.print(gps.altitude.miles());
Serial.print(F(" KM="));
Serial.print(gps.altitude.kilometers());
Serial.print(F(" Feet="));
Serial.println(gps.altitude.feet());
else if (gps.satellites.isUpdated())
Serial.print(F("SATELLITES Fix Age="));
Serial.print(gps.satellites.age());
Serial.print(F("ms Value="));
Serial.println(gps.satellites.value());
else if (gps.hdop.isUpdated())
Serial.print(F("HDOP Fix Age="));
Serial.print(gps.hdop.age());
Serial.print(F("ms raw="));
Serial.print(gps.hdop.value());
Serial.print(F(" hdop="));
Serial.println(gps.hdop.hdop());
else if (millis() - last > 5000)
if (gps.location.isValid())
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
double distanceToLondon =
TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
double courseToLondon =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
Serial.print(F("LONDON Distance="));
Serial.print(distanceToLondon/1000, 6);
Serial.print(F(" km Course-to="));
Serial.print(courseToLondon, 6);
Serial.print(F(" degrees ["));
Serial.print(TinyGPSPlus::cardinal(courseToLondon));
Serial.println(F("]"));
Serial.print(F("DIAGS Chars="));
Serial.print(gps.charsProcessed());
Serial.print(F(" Sentences-with-Fix="));
Serial.print(gps.sentencesWithFix());
Serial.print(F(" Failed-checksum="));
Serial.print(gps.failedChecksum());
Serial.print(F(" Passed-checksum="));
Serial.println(gps.passedChecksum());
if (gps.charsProcessed() < 10)
Serial.println(F("WARNING: No GPS data. Check wiring."));
last = millis();
srnet
January 22, 2022, 8:17am
7
A Google search on;
Arduino TinyGPS++
Leads to this page;
http://arduiniana.org/libraries/tinygpsplus/
Scroll down this reference for TinyGPS++ and you should find the function you want.
This one. The function called TinyGPSPlus::distanceBetween(). It returns the distance in kilometers.
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
srnet
January 22, 2022, 2:54pm
9
Indeed, so.
I have tested it by giving a tracker the co-ordinates of a GPS reference station, the location of these (in the UK) are known to a couple of cm.
The tracker was reading a good GPS with a good view of the Sky and horizon, when I was 25M away from the reference location, the tracker got the calculation accurate to around 1M.
from the examples can i use it when its the last live location?
static double LastLAT = 51.508131;
static double lastLON = -0.128002;
double newLat = gps.location.lat();
double newLon = gps.location.lng();
double distanceSinceLastLocation =
newLat, newLon,
lastLAT, lastLON);
lastLAT = newLat;
lastLon = newLon;
system
Closed
July 22, 2022, 3:13pm
12
