Combination of functions
As im new to Arduino , i built industrial machines and i think it will be a good help for me , I want to put an example on a machine how it run and if there a comment on the parts please also note it.
(ORDER)paper roll driven by a step motor main drive (ORDER)every 2 meters the driver will stop due to a limit switch ,(ORDER) cutter saw will cut the paper driven by a step motor it will hit another limit switch (ORDER) it will return to its original place hit a limit switch which will order the main drive to run again and it will continue in this way.
we do this things normaly with electrical contactors relays switchs buttons ,or plc modes , so why not jump with your help to another level with Arduino.
request= can any respond with the programming of this function using arduino? only the programming write it as it should be in detail in the sketch ?
Thank you
if i have an idea i would write it but i dont just checking if i can get an idea, can i go on , i dont even have an arduino ,
i assume u didnt understand my request
My friend , as i said before that i program machines with plc , so that mean i have already studied logics i even program with C even G codes even i downloaded the arduino program and fill it in C programming and it kept asking me to identify the int; which i already did like i always do in C so i tested my result on the c++ program and there was no errors , so i went into this very website and searched for int and i discoverer that var must be added and it went ok , so its not simpler than the C in which it should be , i ant to take a basic from a machine that i know how it work and compere it to my work and the programs that we use instead of digging my self , and as you said before that i must pay for some body to type me the programming i honestly said to myself woow this program is really not simple , but still i read that its much much simpler .
well i decided to pay you though im convinced not going to use it but i want to know and fast dont have time to dig in this , im out of the states and i can pay only westernunion or money gram or bank swift only if you agree ?
Can you post the code you're having trouble using with the Arduino?
Also let us know what error messages you are getting.
