Combine 2 sketches - password protected webserver that controls relay
2 questions
Question 1:
I have found two example sketches online , one where you make an arduino webserver that allows to control a relay. The other is a sketch that puts a username and password on the arduino webserver. I would like to combine these 2, so that before you get acces to the page where you control the relay you first have to log on with the correct username and password. How can i do this?
Question 2:
Is there a way to move al the HTML code to the SD card, the way the relay webserver works is by altering the html code within de arduino code (when you click the button the page chages to /relay1on or /relay1off), this means that the html code is scattered arround the sketch, so it doesnt work by making a simple index.htm file. How can i do this?
code for the webserver with relay:
(i found it here: Arduino Ethernet Web Server Relay | Random Nerd Tutorials)
 * Rui Santos
 * Complete Project Details https://randomnerdtutorials.com
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,32);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// Relay state and pin
String relay1State = "Off";
const int relay = 7;
// Client variables
char linebuf[80];
int charcount=0;
  // Relay module prepared
  pinMode(relay, OUTPUT);
  digitalWrite(relay, HIGH);
  // Open serial communication at a baud rate of 9600
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
// Display dashboard page with on/off button for relay
// It also print Temperature in C and F
void dashboardPage(EthernetClient &client) {
  client.println("<!DOCTYPE HTML><html><head>");
  client.println("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\"></head><body>");
  client.println("<h3>Arduino Web Server - <a href=\"/\">Refresh</a></h3>");
  // Generates buttons to control the relay
  client.println("<h4>Relay 1 - State: " + relay1State + "</h4>");
  // If relay is off, it shows the button to turn the output on
  if(relay1State == "Off"){
    client.println("<a href=\"/relay1on\"><button>ON</button></a>");
  // If relay is on, it shows the button to turn the output off
  else if(relay1State == "On"){
    client.println("<a href=\"/relay1off\"><button>OFF</button></a>");
  client.println("</body></html>");
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    memset(linebuf,0,sizeof(linebuf));
    charcount=0;
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
       char c = client.read();
       //read char by char HTTP request
        linebuf[charcount]=c;
        if (charcount<sizeof(linebuf)-1) charcount++;
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          dashboardPage(client);
        if (c == '\n') {
          if (strstr(linebuf,"GET /relay1off") > 0){
          else if (strstr(linebuf,"GET /relay1on") > 0){
            digitalWrite(relay, LOW);
            relay1State = "On";
          // you're starting a new line
          charcount=0;
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
Code for webserver with username and password:
(https://forum.arduino.cc/index.php?topic=318538.0)
* Web Server
* A simple web server with basic HTTP authentication
* Circuit:
* Ethernet shield attached to Arduino board
* Analog inputs attached to pins A0 through A5 (optional)
#include <SPI.h>
byte mac[] = {
IPAddress ip(192,168,2, 111);
  server.begin();
void SendOKpage(EthernetClient &client)
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
                    // add a meta refresh tag, so the browser pulls again every 5 seconds:
          client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
void SendAuthentificationpage(EthernetClient &client)
          client.println("HTTP/1.1 401 Authorization Required");
          client.println("WWW-Authenticate: Basic realm=\"Secure Area\"");
          client.println();
          client.println("<HTML>  <HEAD>   <TITLE>Error</TITLE>");
          client.println(" </HEAD> <BODY><H1>401 Unauthorized.</H1></BODY> </HTML>");
char linebuf[80];
int charcount=0;
boolean authentificated=false;
  if (client) {
    charcount=0;
        Serial.write(c);
          if (authentificated)
            SendOKpage(client);
            SendAuthentificationpage(client);
        if (c == '\n') {
          if (strstr(linebuf,"Authorization: Basic")>0 && strstr(linebuf,"cGhwOm5laW4=")>0)
            authentificated=true;
          charcount=0;
    delay(1);
    client.stop();
One has a function, SendOKpage(), that sends something after the user authenticates. The other has a function, dashboardPage(). Make SendOKpage() do what dashboardPage() does.
This worked perfectly, thank you very much
