combine programing need help~
Hi~ i need help~
I want to make two sketches into a single sketch file.
One is ‘DotMatrix clock’ sketch.
Another one is ‘TM1637,DHT22’ temprature sketch.
I was a beginner, but I combined the two sketches together.
‘DotMatrix clock’ works well, but ‘TM1637,DHT22’ does not work.
Only once in one run and stops. (- YouTube)
I don’t know where to fix it. what’s wrong?
Please look attachment file (DotMatrix) + (TM1637_DHT22) ===> (combine.txt)
DotMatrix.txt (45 KB)
TM1637_DHT22.txt (1.91 KB)
Merge_Code.txt (46.8 KB)
You have a lot of stuff there. Put in Serial.print statements to see what code is running and get an idea of where it is not doing what you expect.
CrossRoads: You have a lot of stuff there. Put in Serial.print statements to see what code is running and get an idea of where it is not doing what you expect.
And stop creating new threads on the same topic.
