Hi all,
Hope someone is able to help me.
I'm trying to control multiple relays trough MQTT. My idea is to combine the topic & payload into 1 string, and then with an if function; set the relay state.
I'm using the arduinoMQTTclient library. This is also sending DHT22 info back to home assistant.
For example;
- topic = home/hok/relay1/set
- payload = 0 (off from home assistant)
then set relay 1 to LOW
I cannot manage to combine the topic + payload in 1 string so that i can check it against a single line of text, for example;
if MQTT_string = home/hok/relay1/set_0 then switch relay 1 OFF.
the relevant piece of code (in the loop) is this;
//MQTT berichten uitlezen en relays sturen (continu)
int messageSize = mqttClient.parseMessage();
if (messageSize) { // we received a message, print out the topic and contents
Serial.print("Received a message with topic '");
Serial.println(mqttClient.messageTopic());
Serial.println(String(mqttClient.messageTopic())); // test om te kijken of string hier werkt
Serial.print("Payload: ");
Serial.println((char)mqttClient.read());
String MQTT_string = mqttClient.messageTopic() + "_" + ((char)mqttClient.read());
Serial.print("String; ");
Serial.println(MQTT_string); //geeft nog niet de topic + payload
if (MQTT_string == "home/hok/relay1/set_0") { digitalWrite(relay_1, LOW);} //werkt nog niet omdat string niet correct is
if (MQTT_string == "home/hok/relay1/set_1") { digitalWrite(relay_1, HIGH);}
the serial monitor shows the following;
Received a message with topic 'home/hok/relay1/set
home/hok/relay1/set
Payload: 0
String; _�
So separatly, the topic and payload are shown correctly in the serial monitor, but as soon as try to combine them in 1 string, the code behaves different then I expect it.
I think the string usage of me is incorrect, but I don't know how to fix this.
Any help is appreciated!
For reference; hereby the full code (still under construction);
#include <SPI.h>
#include <ArduinoMqttClient.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
#include "DHT.h"
#include <Wire.h>
#include <hd44780.h> // main hd44780 header lcd driver
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header lcd driver
//LCD
hd44780_I2Cexp lcd; // declare lcd object: auto locate & auto config expander chip
// LCD geometry
const int LCD_COLS = 20;
const int LCD_ROWS = 4;
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the WiFi radio's status
int ledState = LOW; //ledState used to set the LED
bool relayState1 = false;
bool relayState2 = false;
bool relayState3 = false;
bool relayState4 = false;
bool relayState5 = false;
bool relayState6 = false;
bool relayState7 = false;
bool relayState8 = false;
WiFiClient wifiClient;
MqttClient mqttClient(wifiClient);
const char broker[] = "192.168.1.30";
int port = 1883;
const char temph_topic[] = "home/hok/temperatuur_hok";
const char rvh_topic[] = "home/hok/luchtvochtigheid_hok";
const char tempk_topic[] = "home/hok/temperatuur_kas";
const char rvk_topic[] = "home/hok/luchtvochtigheid_kas";
const char wifi_sterkte_topic[] = "home/hok/wifi_sterkte";
const char relay1_topic[] = "home/hok/relay1/set";
const char relay2_topic[] = "home/hok/relay2/set";
const char relay3_topic[] = "home/hok/relay3/set";
const char relay4_topic[] = "home/hok/relay4/set";
const char relay5_topic[] = "home/hok/relay5/set";
const char relay6_topic[] = "home/hok/relay6/set";
const char relay7_topic[] = "home/hok/relay7/set";
const char relay8_topic[] = "home/hok/relay8/set";
//set interval for sending messages (milliseconds)
const long interval = 8000;
unsigned long previousMillis = 0;
int count = 0;
//DHT22 setup
#define DHTPIN 10 // input pin 10 voor hok en 11 voor kas
#define DHTTYPE DHT22 // sensor type
DHT dht(DHTPIN, DHTTYPE);
//relay setup
int relay_1 = 2;
int relay_2 = 3;
int relay_3 = 4;
int relay_4 = 5;
int relay_5 = 6;
int relay_6 = 7;
int relay_7 = 8;
int relay_8 = 9;
//LCD icoontjes
byte hokchar[8] {B00000, B00100, B01110, B11111, B11001, B11001, B11111, B11111,}; //icoontje van een hok of huisje
byte kaschar[8] {B00000, B00000, B00100, B01010, B10001, B10001, B10001, B11111,}; //icoontje van een leeg huis of kas
byte wifi1char[8] {B00000, B00000, B00000, B00000, B00000, B00000, B00000, B00100,}; //WiFi icoontje met 1 streepje
byte wifi2char[8] {B00000, B00000, B00000, B00000, B00100, B01010, B00000, B00100,}; //WiFi icoontje met 2 streepjes
byte wifi3char[8] {B00000, B00000, B01110, B10001, B00100, B01010, B00000, B00100,}; //WiFi icoontje met 3 streepjes
byte wifi4char[8] {B01110, B10001, B01110, B10001, B00100, B01010, B00000, B00100,}; //Wifi icoontje met 4 streepjes
pinMode(LED_BUILTIN, OUTPUT);// set the LED as output
//relay setup en alle relays uitschakelen
pinMode(relay_1, OUTPUT);
pinMode(relay_2, OUTPUT);
pinMode(relay_3, OUTPUT);
pinMode(relay_4, OUTPUT);
pinMode(relay_5, OUTPUT);
pinMode(relay_6, OUTPUT);
pinMode(relay_7, OUTPUT);
pinMode(relay_8, OUTPUT);
digitalWrite(relay_2, HIGH);
digitalWrite(relay_3, HIGH);
digitalWrite(relay_4, LOW);
digitalWrite(relay_5, LOW);
digitalWrite(relay_6, LOW);
digitalWrite(relay_7, LOW);
digitalWrite(relay_8, LOW);
//LCD
int status; // initialize LCD with number of columns and rows: status = lcd.begin(LCD_COLS, LCD_ROWS);
if(status) // non zero status means it was unsuccesful
// hd44780 has a fatalError() routine that blinks an led if possible
// begin() failed so blink error code using the onboard LED if possible
hd44780::fatalError(status); // does not return
// initalization was successful, the backlight should be on now
// Print a message to the LCD
lcd.setCursor(0, 0);
lcd.print("Hoi pap :-)");
lcd.setCursor(0, 1);
lcd.print("Computer start op");
lcd.createChar(1,hokchar);
//Initialize serial (and wait for port to open:)
//while (!Serial) { } ; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection: (aangepast naar 5 sec)
delay(5000);
Serial.println("You're connected to the network");
LED_Blink();
LED_Blink();
delay(100);
lcd.setCursor(0, 2);
lcd.print("WiFi verbonden");
mqttClient.setUsernamePassword(SECRET_MQTT_User, SECRET_MQTT_PW);
Serial.print("Attempting to connect to the MQTT broker: ");
Serial.println(broker);
if (!mqttClient.connect(broker, port)) {
Serial.print("MQTT connection failed! Error code = ");
Serial.println(mqttClient.connectError());
while (1);
// mqttClient.subscribe(relays_topic); //verzamel topic om alle relay aansturing uit te lezen
mqttClient.subscribe(relay1_topic);
mqttClient.subscribe(relay2_topic);
mqttClient.subscribe(relay3_topic);
mqttClient.subscribe(relay4_topic);
mqttClient.subscribe(relay5_topic);
mqttClient.subscribe(relay6_topic);
mqttClient.subscribe(relay7_topic);
mqttClient.subscribe(relay8_topic);
Serial.println("You're connected to the MQTT broker!");
LED_Blink();
LED_Blink();
LED_Blink();
dht.begin();
lcd.setCursor(0, 3);
lcd.print("Verbonden met server");
//maak LCD scherm leeg
delay(2000);
lcd.clear();
//LCD_clear(); // zelf geschreven code, backup als lcd.clear niet werkt.
// while (mqttClient.available()) {
// Serial.print((char)mqttClient.read());
// periodiek meetwaarden naar MQTT broker sturen;
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis; // save the last time a message was sent
digitalWrite(LED_BUILTIN, HIGH);
//temp en luchtvochtigheid meting
float hh = dht.readHumidity(); //luchtvochtigheid hok
float th = dht.readTemperature(); // temperatuur hok
float hk = dht.readHumidity(); //luchtvochtigheid kas
float tk = dht.readTemperature(); //temperatuur kas
// Check if any reads failed and exit early (to try again). //tijdelijk uitgeschakeld voor testen MQTT
if (isnan(h) || isnan(t)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
printCurrentNet();
Serial.print(F("Humidity: "));
Serial.print(hh);
Serial.print(F("% Temperature: "));
Serial.print(th);
Serial.println(F("°C "));
Serial.print("Sending message to temph.topic: ");
Serial.println(temph_topic);
Serial.println(th);
Serial.print("Sending message to RVh.topic: ");
Serial.println(rvh_topic);
Serial.println(hh);
Serial.print("Sending message to Wifi_sterkte.topic: ");
Serial.println(wifi_sterkte_topic);
Serial.println(WiFi.RSSI());
// send message, the Print interface can be used to set the message contents
mqttClient.beginMessage(temph_topic);
mqttClient.print(th);
mqttClient.endMessage();
mqttClient.beginMessage(rvh_topic);
mqttClient.print(hh);
mqttClient.beginMessage(wifi_sterkte_topic);
mqttClient.print(WiFi.RSSI());
//Serial.println();
digitalWrite(LED_BUILTIN, LOW);
//LCD weergave
lcd.clear();
delay(10);
lcd.setCursor(0,0);
lcd.write(1);
lcd.setCursor(1,0);
lcd.print(th);
lcd.setCursor(3,0);
lcd.print("°C ");
lcd.setCursor(6,0);
lcd.print(hh);
lcd.setCursor(7,0);
lcd.print("% ");
void printCurrentNet() {
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
void LED_Blink() {
delay(50);
delay(50);
void LCD_clear() {
lcd.print(" ");
lcd.print(" ");
lcd.print(" ");
lcd.print(" ");
