Hi
I just got my first arduino uno and I wanted to start with an led project.
One part is a knight rider led array with 6 led's and the other is just an led which fades (sketch).
I wanted to combine the two codes, so they can run simultaneously but after a lot of trial and error I still cant figure it out...
I would be really thankful if someone could do this for me or show me how.
here are the codes:
/* Knight Rider 3
- This example concentrates on making the visuals fluid.
- (cleft) 2005 K3, Malmo University
- @author: David Cuartielles
@hardware: David Cuartielles, Aaron Hallborg
int pinArray[] = {2, 3, 4, 5, 6, 7};
int count = 0;
int timer = 30;
void setup(){
for (count=0;count<6;count++) {
pinMode(pinArray[count], OUTPUT);
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
for (count=0;count<5;count++) {
digitalWrite(pinArray[count], HIGH);
delay(timer);
digitalWrite(pinArray[count + 1], HIGH);
delay(timer);
digitalWrite(pinArray[count], LOW);
delay(timer2);
for (count=5;count>0;count--) {
delay(timer);
digitalWrite(pinArray[count - 1], HIGH);
delay(timer);
delay(timer2);
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255) {
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
Fade
This example shows how to fade an LED on pin 9 using the analogWrite()
function.
The analogWrite() function uses PWM, so if you want to change the pin you're
using, be sure to use another PWM capable pin. On most Arduino, the PWM pins
are identified with a "~" sign, like ~3, ~5, ~6, ~9, ~10 and ~11.
This example code is in the public domain.
int led = 9; // the PWM pin the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
// the loop routine runs over and over again forever:
delay(30);
sorry for my bad enlgish
