Hello
I'm trying to get an Altimeter MS5607 to measure height, pressure and temperature (i know, that's what it always does, but I'm trying to get it to show me the temperature and pressure too). I also want it to save the measurements on an SD card, using the SD Breakout from Adafruit. Here are the codes to measure temperature+pressure and for height. They both work separately, but not combined.
I don't get any errors when I upload the code, but it doesn't show anything on the serial monitor. It would be really nice if someone could help me.
temperature + pressure
#include <Wire.h>
#define ADDRESS 0x77 //0x76
uint32_t D1 = 0;
uint32_t D2 = 0;
int32_t dT = 0;
int32_t TEMP = 0;
int64_t OFF = 0;
int64_t SENS = 0;
int32_t P = 0;
uint16_t C[7];
// Disable internal pullups, 10Kohms are on the breakout
PORTC |= (1 << 4);
PORTC |= (1 << 5);
Wire.begin();
Serial.begin(9600); //9600 changed 'cos of timing?
delay(100);
initial(ADDRESS);
D1 = getVal(ADDRESS, 0x48); // Pressure raw
D2 = getVal(ADDRESS, 0x58);// Temperature raw
dT = D2 - (C[4]*256);
TEMP = 2000 + ((dT * C[5])/8388608);
OFF = ((C[1])<<16) + ((C[3] * dT) >> 7);
SENS = ((C[0])<<15) + ((C[2] * dT) >> 8);
P = ((D1 * SENS/2097152 - OFF)/32768)/100;
Serial.print(" Actual TEMP= ");
Serial.print(TEMP);
Serial.print(" Actual PRESSURE= ");
Serial.print(P);
Serial.print(" RAW Temp D2= ");
Serial.print(D2);
Serial.print(" RAW Pressure D1= ");
Serial.println(D1);
Serial.print(" dT= ");
Serial.println(dT);
Serial.print(" C0/1= ");
Serial.println(C[0]);
Serial.print(" C1/2= ");
Serial.println(C[1]);
Serial.print(" C2/3= ");
Serial.println(C[2]);
Serial.print(" C3/4= ");
Serial.println(C[3]);
Serial.print(" C4/5= ");
Serial.println(C[4]);
Serial.print(" C5/6= ");
Serial.println(C[5]);
Serial.print(" C6/7= ");
Serial.println(C[6]);
Serial.print(" C7/8= ");
Serial.println(C[7]);
delay(1000
long getVal(int address, byte code)
unsigned long ret = 0;
Wire.beginTransmission(address);
Wire.write(code);
Wire.endTransmission();
delay(10);
// start read sequence
Wire.write((byte) 0x00);
Wire.requestFrom(address, (int)3);
if(Wire.available()) {
// ret = ((uint32_t)Wire.read() << 16) | ((uint32_t)Wire.read() << 8) | Wire.read();
ret = Wire.read() * 65536 + Wire.read() * 256 + Wire.read();
else {
ret = -1;
return ret;
void initial(uint8_t address)
Serial.println("PROM COEFFICIENTS ivan");
Wire.write(0x1E); // reset
delay(10);
for (int i=0; i<7 ; i++) {
Wire.write(0xA2 + (i * 2));
Wire.requestFrom(address, (uint8_t) 6);
delay(1);
C[i] = Wire.read() *256 + Wire.read();
else {
Serial.println("Error reading PROM 1"); // error reading the PROM or communicating with the device
Serial.println(C[i]);
Height + save it on an SD card
#include <SD.h> // to use Adafruit SD breakout board
#include <Wire.h> // to use I2C
#include "IntersemaBaro.h" // to use Altimeter Module MS5607
#define BUTTON 7 // Button wordt uitgelezen aan poort 7
File dataFile; // declaration of dataFile
const int chipSelect = 10; //Arduino Nano uses CS = 10
unsigned long time = 0; // declaration of time variable
int val = LOW; // variabele waarde button, initieel low
//int old_val = LOW; // variabele waarde button na cyclus in void loop
//int bezig = HIGH; // variabele om na te gaan of button actief is
Intersema::BaroPressure_MS5607B baro(true);
Serial.begin(9600); // setting the bit rate per second
baro.init(); // initialising the Altimeter Module MS5607
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT); // needed for the SD card, making SPI connection
pinMode (BUTTON,INPUT); // Button is input voor poort 7
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
// adding a header to the file data.txt
dataFile = SD.open("data.txt", FILE_WRITE); // open the file data.txt
dataFile.print("time (s)");
dataFile.print("\t"); // add tab
dataFile.print("height (cm)");
dataFile.println(); // carriage return
dataFile.close(); //close file data.txt
val = digitalRead (BUTTON); // lees waarde button
if ((val == HIGH)) { // als button aanstaat en eerste cyclus van de void loop sinds het aanzetten nog niet voltooid is
//bezig = digitalRead(BUTTON); //nagegaan of button nog steeds aanstaat
time = millis();
int alt = baro.getHeightCentiMeters(); //measure height in centimeter
dataFile.print(time); // print time
dataFile.print((float)(alt)); // print altitude
dataFile.println(); // add empty line
dataFile.close(); // close file data.txt
// print to the serial port too:
Serial.print((time)); // print time
Serial.print("\t"); // add tab
Serial.print("height (cm): ");
Serial.print((float)(alt)); // print altitude
Serial.println(); // carriage return
