#include <WiFi.h>
#include <Firebase_ESP_Client.h>
#include "addons/TokenHelper.h"
#include "addons/RTDBHelper.h"
#include <ACS712.h>
#define WIFI_SSID ""
#define WIFI_PASSWORD ""
#define DATABASE_URL ""
#define API_KEY ""
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
#define RELAY_A_PIN 2
#define RELAY_B_PIN 0
#define RELAY_C_PIN 32
#define RELAY_D_PIN 33
unsigned long sendDataPrevMillis = 0;
bool signupOK = false;
String prevValue = "";
// Relay states
int relayStateA = LOW;
int relayStateB = LOW;
int relayStateC = LOW;
int relayStateD = LOW;
// ACS712 variables
ACS712 sensor(ACS712_30A, 4);
sensor.calibrate();
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
/* Assign the api key (required) */
config.api_key = API_KEY;
/* Assign the RTDB URL (required) */
config.database_url = DATABASE_URL;
/* Sign up */
if (Firebase.signUp(&config, &auth, "", "")) {
Serial.println("ok");
signupOK = true;
else {
Serial.printf("%s\n", config.signer.signupError.message.c_str());
/* Assign the callback function for the long-running token generation task */
config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
Firebase.begin(&config, &auth);
Firebase.reconnectWiFi(true);
pinMode(RELAY_A_PIN, OUTPUT);
pinMode(RELAY_B_PIN, OUTPUT);
pinMode(RELAY_C_PIN, OUTPUT);
pinMode(RELAY_D_PIN, OUTPUT);
if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 15000 || sendDataPrevMillis == 0)) {
sendDataPrevMillis = millis();
if (Firebase.RTDB.getString(&fbdo, "relay")) {
if (fbdo.dataType() == "string") {
String stringValue = fbdo.stringData();
Serial.print("Received value from Firebase: ");
Serial.println(stringValue);
if (stringValue != prevValue) { // Check if value changed
prevValue = stringValue; // Update previous value
updateRelays(stringValue);
Serial.println("Invalid data type received from Firebase");
Serial.println("Error reading from Firebase");
Serial.println(fbdo.errorReason());
float I = sensor.getCurrentAC();
// Update Firebase with watts value
Serial.println(I);
delay(1000); // Delay added for stability
void updateRelays(String value) {
if (value == "1") {
relayStateA = HIGH;
relayStateB = LOW;
relayStateC = LOW;
relayStateD = LOW;
} else if (value == "2") {
relayStateA = LOW;
relayStateB = HIGH;
relayStateC = LOW;
relayStateD = LOW;
} else if (value == "3") {
relayStateA = LOW;
relayStateB = LOW;
relayStateC = HIGH;
relayStateD = LOW;
} else if (value == "4") {
relayStateA = LOW;
relayStateB = LOW;
relayStateC = LOW;
relayStateD = HIGH;
} else if (value == "5") { // Adding condition for new relay state
relayStateA = LOW;
relayStateB = LOW;
relayStateC = LOW;
relayStateD = LOW;
// Invalid value, turn off all relays
relayStateA = LOW;
relayStateB = LOW;
relayStateC = LOW;
relayStateD = LOW;
Serial.println("Invalid value, turning off all relays");
// Update relay states
digitalWrite(RELAY_A_PIN, relayStateA);
digitalWrite(RELAY_B_PIN, relayStateB);
digitalWrite(RELAY_C_PIN, relayStateC); // Control the new relay pin
digitalWrite(RELAY_D_PIN, relayStateD);
-the code works if separated but when combined the acs712 out is
200.09
200.09
200.09
200.09
