Combining 2 codes of an arduino car
Hey. I've built a bluetooth car with an ultrasonic sensor and a servomotor, but the problem is that I don't have a code for it, for now I have a code only for bluetooth, so the sensor is useless. I've watched 2 videos, one just for a bluetooth car and one just for an obstacle avoiding car and I've tried to combine the codes but it didn't work. I didn't copy the movement code twice, I got it from the bluetooth code and tried to add only the servomotor and ultrasonic sensor from the other one. Can someone please help me?
The bluetooth code :
#include <AFMotor.h>
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
char command;
  Serial.begin(9600);  //Set the baud rate to your Bluetooth module.
void loop(){
  if(Serial.available() > 0){
    command = Serial.read();
    Stop(); //initialize with motors stoped
    //Change pin mode only if new command is different from previous.
    //Serial.println(command);
    switch(command){
    case 'F':
      forward();
    case 'B':
       back();
  case 'L':
      left();
    case 'R':
      right();
void forward()
  motor1.setSpeed(255); //Define maximum velocity
  motor1.run(FORWARD); //rotate the motor clockwise
  motor2.setSpeed(255); //Define maximum velocity
  motor2.run(FORWARD); //rotate the motor clockwise
  motor3.setSpeed(255);//Define maximum velocity
  motor3.run(FORWARD); //rotate the motor clockwise
  motor4.setSpeed(255);//Define maximum velocity
  motor4.run(FORWARD); //rotate the motor clockwise
void back()
  motor1.run(BACKWARD); //rotate the motor anti-clockwise
  motor2.run(BACKWARD); //rotate the motor anti-clockwise
  motor3.setSpeed(255); //Define maximum velocity
  motor3.run(BACKWARD); //rotate the motor anti-clockwise
  motor4.setSpeed(255); //Define maximum velocity
  motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
void right()
void Stop()
  motor1.setSpeed(0); //Define minimum velocity
  motor1.run(RELEASE); //stop the motor when release the button
  motor2.setSpeed(0); //Define minimum velocity
  motor2.run(RELEASE); //rotate the motor clockwise
  motor3.setSpeed(0); //Define minimum velocity
  motor3.run(RELEASE); //stop the motor when release the button
  motor4.setSpeed(0); //Define minimum velocity
  motor4.run(RELEASE); //stop the motor when release the button
The obstacle avoiding code :
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 200
#define MAX_SPEED 190 // sets speed of DC  motors
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
  distance = readPing();
  delay(100);
delay(100);
  delay(100);
  delay(100);
 int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=15)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  distanceR = lookRight();
  delay(200);
  distanceL = lookLeft();
  delay(200);
  if(distanceR>=distanceL)
turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
int lookRight()
    myservo.write(50);
    int distance = readPing();
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  int cm = sonar.ping_cm();
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
void moveForward() {
 if(!goesForward)
    goesForward=true;
   for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
    motor1.setSpeed(speedSet);
    motor2.setSpeed(speedSet);
    motor3.setSpeed(speedSet);
    motor4.setSpeed(speedSet);
    delay(5);
void moveBackward() {
    goesForward=false;
    delay(5);
void turnRight() {
void turnLeft() {
What I have tried:
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
char command;
Servo myservo;
int distance = 100;
int speedSet = 0;
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
void loop(){
    switch(command){
    case 'F':
      forward();
    case 'B':
       back();
    case 'L':
      left();
    case 'R':
      right();
  int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=15)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  delay(200);
  delay(200);
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
int lookRight()
    myservo.write(50);
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  if(cm==0)
    cm = 250;
  return cm;
void forward()
void back()
void left()
void right()
void Stop()
Please post your code here, in code tags.
Done.
Please post your code in code tags:
An example of code posted in code tags, See how it differs from your done?
Done. Hope this time I got it right
What does that mean?
Example, I have an issue, my code don't work. Is that a helpful statement to you?
Could you describe in more detail what did not work?
The car isn't moving at all.
Have you considered putting in some Serial.print( print things so I can see what the going on )?
I was getting an error on a function, solved it but the program is still not working. Now I've tried this :
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
Servo myservo;
char command;
int distance = 100;
int speedSet = 0;
void loop(){
    switch(command){
    case 'F':
      forward();
    case 'B':
       back();
    case 'L':
      left();
    case 'R':
      right();
 if(Serial.available() == 0){
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=15)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  delay(200);
  delay(200);
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
void forward()
void back()
void left()
void right()
void Stop()
int lookRight()
    myservo.write(50);
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
 if(!goesForward)
    goesForward=true;
    delay(5);
    goesForward=false;
    delay(5);
void turnRight() {
void turnLeft() {
Basically this code should work as an obstacle avoiding car while the car isn't connected to bluetooth and controllable through an android app while connected.
I've got to a point where the car was able to tell the difference between being connected and not, but while I was connected there was a big delay, like I was pressing forward and the car was moving after 2 seconds. Now, I'm stuck here.
You are bugging about a lack or responsiveness when the above code contains over 2 seconds of delay.
Humm?
Those 2 second delays could be related to your code and its heavy use of delay.
Yes, but I want this to happen only when I'm not connected to the bluetooth. The servo and the sensor must be inactive while the bluetooth is connected.
I've done it. It is always connected to bluetooth and when I press a button (case X), it acts as an obstacle avoiding car and I've made it to stop when you put your hand in front of the sensor (distance <=3cm), after that it works like a bluetooth car again.
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
Servo myservo;
char command;
int distance = 100;
int speedSet = 0;
int StopSpecial = 0;
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
    switch(command){
    case 'F':
      forward();
    case 'B':
       back();
    case 'L':
      left();
    case 'R':
      right();
    case 'X':
      Obstacle();
void Obstacle()
while (command == 'X')
int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=15)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  delay(200);
  delay(200);
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
 if(distance <=3) break;
int lookRight()
    myservo.write(50);
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
 if(!goesForward)
    goesForward=true;
    delay(5);
    goesForward=false;
    delay(5);
void turnRight() {
void turnLeft() {
void forward()
void back()
void left()
void right()
void Stop()
