I am trying to combine a servo with a touch sensor/ infrared sensor so they will turn the servo on and cause it to rotate 100 degrees or so and come back. I am using an Arduino Uno. My code for the sensors is
// Henry's Bench
// Capacitive Touch Sensor Tutorial
// When Sig Output is high, touch sensor is being pressed
#define ctsPin 2 // Pin for capactitive touch sensor
int LDR = 0;
int ledPin = 13; // pin for the LED
pinMode(ledPin, OUTPUT);
pinMode(ctsPin, INPUT);
pinMode(LDR, INPUT);
int ctsValue = digitalRead(ctsPin);
if (ctsValue == HIGH) {
digitalWrite(ledPin, HIGH);
Serial.println("TOUCHED");
else {
digitalWrite(ledPin, LOW);
Serial.println("not touched");
int v = analogRead(LDR);
Serial.println(v);
and my code so far for the servo to move is
/* Sweep
by BARRAGAN <http://barraganstudio.com>
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
/* Sweep
modified 8 Nov 2013
by Scott Fitzgerald
// Henry's Bench
int LDR = 0;
#include <Servo.h>
else {
Serial.println(v);
No. You have a bunch of code hanging outside of any function (look at the } that closes setup(). In that code are pinMode statements that belong in setup() and code that belongs in loop().
This is as corrected as I can get it without the hardware. Compiles with ver 1.6.5, Win10.
/* Sweep
modified 8 Nov 2013
by Scott Fitzgerald
// Henry's Bench
int LDR = 0;
#include <Servo.h>
else {
Serial.println(v);
// you might want a delay here to slow the servo?
Leave "void setup()" behind, move all the junk to the destination's setup.
Do the same with "void loop()".
Check for pin conflicts and order the program sensibly, such as putting a button reading before whatever would happen as a result of the button being used.
okay i believe this is what you are trying to achieve.
#include <Servo.h>
Servo myservo;
int LDR = 0;
int pos = 0;
myservo.attach(9);
else {
Serial.println(v);
this should allow the servo to spin to one position when the sensor is pressed and then spin back when it is no longer pressed. i understand my commenting is not the best but just ask questions if you dont understand why i have done it this way.
