I need assisting on combining the Adafruit Trellis sketch and standardfirmata sketch. I can successfully upload the two, but there is conflict with the serial readings.
Here is the Trellis Sketch:
This is a test example for the Adafruit Trellis w/HT16K33
Designed specifically to work with the Adafruit Trellis
----> https://www.adafruit.com/products/1616
----> https://www.adafruit.com/products/1611
These displays use I2C to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
MIT license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_Trellis.h"
This example shows reading buttons and setting/clearing buttons in a loop
"momentary" mode has the LED light up only when a button is pressed
"latching" mode lets you turn the LED on/off when pressed
Up to 8 matrices can be used but this example will show 4 or 1
#define MOMENTARY 0
#define LATCHING 1
// set the mode here
#define MODE LATCHING
Adafruit_Trellis matrix0 = Adafruit_Trellis();
// uncomment the below to add 3 more matrices
Adafruit_Trellis matrix1 = Adafruit_Trellis();
Adafruit_Trellis matrix2 = Adafruit_Trellis();
Adafruit_Trellis matrix3 = Adafruit_Trellis();
// you can add another 4, up to 8
// Just one
Adafruit_TrellisSet trellis = Adafruit_TrellisSet(&matrix0);
// or use the below to select 4, up to 8 can be passed in
//Adafruit_TrellisSet trellis = Adafruit_TrellisSet(&matrix0, &matrix1, &matrix2, &matrix3);
// set to however many you're working with here, up to 8
#define NUMTRELLIS 1
#define numKeys (NUMTRELLIS * 16)
// Connect Trellis Vin to 5V and Ground to ground.
// Connect the INT wire to pin #A2 (can change later!)
#define INTPIN A2
// Connect I2C SDA pin to your Arduino SDA line
// Connect I2C SCL pin to your Arduino SCL line
// All Trellises share the SDA, SCL and INT pin!
// Even 8 tiles use only 3 wires max
Serial.println("Trellis Demo");
// INT pin requires a pullup
pinMode(INTPIN, INPUT);
digitalWrite(INTPIN, HIGH);
// begin() with the addresses of each panel in order
// I find it easiest if the addresses are in order
trellis.begin(0x70); // only one
// trellis.begin(0x70, 0x71, 0x72, 0x73); // or four!
// light up all the LEDs in order
for (uint8_t i=0; i<numKeys; i++) {
trellis.setLED(i);
trellis.writeDisplay();
delay(50);
// then turn them off
trellis.clrLED(i);
delay(50);
delay(30); // 30ms delay is required, dont remove me!
if (MODE == MOMENTARY) {
// If a button was just pressed or released...
if (trellis.readSwitches()) {
// go through every button
// if it was pressed, turn it on
if (trellis.justPressed(i)) {
Serial.print("v"); Serial.println(i);
trellis.setLED(i);
// if it was released, turn it off
if (trellis.justReleased(i)) {
Serial.print("^"); Serial.println(i);
trellis.clrLED(i);
// tell the trellis to set the LEDs we requested
if (MODE == LATCHING) {
// if it was pressed...
Serial.println(i);
// Alternate the LED
if (trellis.isLED(i))
trellis.clrLED(i);
trellis.setLED(i);
I want to still be able to generate readings from the buttons pressed on the trellis and get the LED’s to light up.
If anyone can help me with this, that would be much appreciated
