Hello all,
I'm having trouble to put together 2 codes from 2 different shields... I have an arduino Duemilanove, a datalogger from adafruit and a 32 analogue shield from critical velocity.
the question is how to combine the two standard code in one!
I'm a beginner in arduino but know my electronics! Coding is not my best part but eager to learn from anyone!
here is the part from the "monstermux 32ch analogue shield";
[color=red]/* MonsterMux32 Demo Code
Critical Velocity 2009
This code selects an analog channel and prints the value to the serial port.
For more information, visit www.criticalvelocity.com/mmux32
int sensorValue;
char muxch = 23; // change this to the channel number you wish to read.
// These 6 pins control which analog channel is connected to the Analog Input 0 on the Arduino.
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
// read the value from the sensor:
set_mux(muxch);
// Analog 0 is now connected to input set by muxch.
sensorValue = analogRead(0);
Serial.println(sensorValue);
delay(10);
// The following function selects the channel to be read.
// using PORTB directly is not really recommended for the Arduino environment.
// Feel free to modify the code to avoid direct writes to PORTB.
void set_mux(char channel) {
// sets mux to read selected channel.
if (channel < 32) {
// valid channels are 0-31
PORTB = (PORTB & 0xC0) | channel;
[/color]
and here the code from the datalogger;
[color=green]#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
// A simple data logger for the Arduino analog pins
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL 1000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 2
#define greenLEDpin 3
// The analog pins that connect to the sensors
#define photocellPin 0 // analog 0
#define tempPin 1 // analog 1
#define BANDGAPREF 14 // special indicator that we want to measure the bandgap
#define aref_voltage 3.3 // we tie 3.3V to ARef and measure it with a multimeter!
#define bandgap_voltage 1.1 // this is not super guaranteed but its not -too- off
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
// red LED indicates error
digitalWrite(redLEDpin, HIGH);
while(1);
void setup(void)
// use debugging LEDs
pinMode(redLEDpin, OUTPUT);
pinMode(greenLEDpin, OUTPUT);
#if WAIT_TO_START
Serial.println("Type any character to start");
while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
error("Card failed, or not present");
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
// connect to RTC
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,stamp,datetime,light,temp,vcc");
#if ECHO_TO_SERIAL
Serial.println("millis,stamp,datetime,light,temp,vcc");
// If you want to set the aref to something other than 5v
analogReference(EXTERNAL);
void loop(void)
DateTime now;
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print(", ");
#endif
// fetch the time
now = RTC.now();
// log time
logfile.print(now.unixtime()); // seconds since 1/1/1970
logfile.print('"');
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
logfile.print('"');
#if ECHO_TO_SERIAL
Serial.print(now.unixtime()); // seconds since 1/1/1970
Serial.print(", ");
Serial.print('"');
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
Serial.print('"');
analogRead(photocellPin);
delay(10);
int photocellReading = analogRead(photocellPin);
analogRead(tempPin);
delay(10);
int tempReading = analogRead(tempPin);
// converting that reading to voltage, for 3.3v arduino use 3.3, for 5.0, use 5.0
float voltage = tempReading * aref_voltage / 1024;
float temperatureC = (voltage - 0.5) * 100 ;
float temperatureF = (temperatureC * 9 / 5) + 32;
logfile.print(photocellReading);
logfile.print(temperatureF);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(photocellReading);
Serial.print(", ");
Serial.print(temperatureF);
// Log the estimated 'VCC' voltage by measuring the internal 1.1v ref
analogRead(BANDGAPREF);
delay(10);
int refReading = analogRead(BANDGAPREF);
float supplyvoltage = (bandgap_voltage * 1024) / refReading;
logfile.print(supplyvoltage);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(supplyvoltage);
#endif // ECHO_TO_SERIAL
logfile.println();
#if ECHO_TO_SERIAL
digitalWrite(greenLEDpin, LOW);
// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
// blink LED to show we are syncing data to the card & updating FAT!
logfile.flush();
digitalWrite(redLEDpin, LOW);
[/color]
I tried a few things like combining the void setup and replacing the two void loop by naming them void loop_code 1(); and void loop_code2();
this was not working for me and many errors appeared!
by the way: the code for the light sensor and temperature does not have tobe in there, I want to have a blank shield where I can just put my analogue inputs into it.
My goal is to use this datalogger for monitoring many K-type thermocouples using the AD595 thermocouple chip!
Please, if there's anyone who can help it's very much appreciated!
thank's
rjbtd1
