Motor Shield 1-Channel DC Motor Demo
by Randy Sarafan
For more information see:
http://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/
//Setup Channel A
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
void loop(){
//forward @ full speed
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
analogWrite(3, 255); //Spins the motor on Channel A at full speed
delay(3000);
digitalWrite(9, HIGH); //Eengage the Brake for Channel A
//backward @ half speed
digitalWrite(12, LOW); //Establishes backward direction of Channel A
analogWrite(3, 123); //Spins the motor on Channel A at half speed
delay(3000);
is your motor code, and a quick glance looks like your accessing 3 pins 3 9 and 12..
check your shield documentation to see if it is reserving any other pins for any reason..
if not select one or more unused to assign for your other functions..
probably find 10, 11 are reserved for chanel B but if your not using chanel B chances are u can pass through the shield ok unless the documentation for it states otherwise?
