I am trying to get the my code where if the temp sensore prints “person present” then it starts the temperature sensor up. Help!
#include <WireExt.h>
// TEMP:
int reader ;
void temp_setup() {
//put your setup code here to run once:
pinMode(10 , OUTPUT);
void temp_loop() {
//put your main code here, to run repeatedly:
reader = analogRead(A0);// 0 - 1023
int mV = reader *(5000 / 1024 );
float C = (mV - 500 ) / 10 ;
float F = C * 9.0 / 5.0 + 32 ;
Serial.println(F);
if (F > 30.0 && F <40.0){
alarm1();
} else if (F > 40.0 && F <50.0){
alarm2();
} else if (F > 50.0 && F <75.0){
alarm3();
// This is the lowest level alarm sound
void alarm1() {
analogWrite(10 , 20 ); // 1 - 254
delay (50);
analogWrite(10 , 0);// attempting to make a sound
delay (50);
Serial.println(“alarm 1”);
// This is the second level alarm sound
void alarm2() {
delay (500);
delay (500);
Serial.println(“alarm 2”);
// This is the third level alarm sound
void alarm3() {
delay (5000);
delay (5000);
Serial.println(“alarm 3”);
//Infrared:
// Code from Arduino Forum https://forum.arduino.cc/index.php?topic=217394.0
// Modified to a Serial Output
#include <Wire.h>
#include “WireExt.h”
#define D6T_addr 0x0A // Address of OMRON D6T is 0x0A in hex
#define D6T_cmd 0x4C // Standard command is 4C in hex
int rbuf[35]; // Actual raw data is coming in as 35 bytes. Hence the needed for WireExt so that we can handle more than 32 bytes
int tdata[16]; // The data comming from the sensor is 16 elements, in a 16x1 array
float t_PTAT;
void infrared_setup()
Wire.begin();
pinMode(13, OUTPUT);
void infrared_loop()
int i;
Wire.beginTransmission(D6T_addr);
Wire.write(D6T_cmd);
Wire.endTransmission();
if (WireExt.beginReception(D6T_addr) >= 0) {
i = 0;
for (i = 0; i < 35; i++) {
rbuf = WireExt.get_byte();
- WireExt.endReception();*
t_PTAT = (rbuf[0] + (rbuf[1] << 8)) * 0.1; // Unclear what this is used for. It’s not called elsewhere - for (i = 0; i < 16; i++) {*
tdata = (rbuf[(i * 2 + 2)] + (rbuf[(i * 2 + 3)] << 8)) * 0.1;
* // Data is captured into tdata. This should be a 16x1 data. For now we can output as a csv string which we can import to Matlab to sequence*
* for (i = 0; i < 4; i++) {*
_ Serial.print(tdata*);
Serial.print(",");
Serial.print("\n");
// Data is captured into tdata. This should be a 4x1 data. For now we can output as a csv string which we can import to Matlab to sequence*
* for (i = 4; i < 8; i++) {
Serial.print(tdata);
Serial.print(",");
Serial.print("\n");
* for (i = 8; i < 12; i++) {
Serial.print(",");
Serial.print("\n");
* for (i = 12; i < 16; i++) {
Serial.print(",");
Serial.print("\n");
Serial.print("\n");
int CurrentLowestTemp = 999;
int CurrentHighestTemp = 0;
for (int i = 0; i < 16; i++) {
if (tdata < CurrentLowestTemp) {
CurrentLowestTemp = tdata;
Serial.print("CurrentLowest: ");
Serial.println(CurrentLowestTemp);*_
* for (int i = 0; i < 16; i++) {*
_ if (tdata > CurrentHighestTemp) {
CurrentHighestTemp = tdata*;
Serial.print("CurrentHighest: ");
Serial.println(CurrentHighestTemp);*_
* // (“TempDiff”)*
* int TempDiff = CurrentHighestTemp - CurrentLowestTemp;*
* Serial.print("TempDiff: ");*
* Serial.print(TempDiff);*
* Serial.println();*
* if (TempDiff > 0 && TempDiff < 4) {*
* Serial.print(“Person Not Present”);*
* } else if (TempDiff >= 4) {*
* Serial.print(“Person Present”);*
* delay(4000);*
//COMBINED CODE:
void setup(){
* infrared_setup();
temp_setup();
_}
{*_
infrared_loop();
temp_loop();
