combining codes ???
how do I combine
the code found at
and the code found at
https://create.arduino.cc/projecthub/LiLShReDdeR/charlieplexing-with-arduino-5b4ade
the first base code is
// These variables store the flash pattern
// and the current state of the LED
int ledPin1 = 12; // the number of the LED pin
int ledState1 = LOW; // ledState used to set the LED
unsigned long previousMillis1 = 0; // will store last time LED was updated
long OnTime1 = 250; // milliseconds of on-time
long OffTime1 = 750; // milliseconds of off-time
int ledPin2 = 13; // the number of the LED pin
int ledState2 = LOW; // ledState used to set the LED
unsigned long previousMillis2 = 0; // will store last time LED was updated
long OnTime2 = 330; // milliseconds of on-time
long OffTime2 = 400; // milliseconds of off-time
// set the digital pin as output:
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
// check to see if it's time to change the state of the LED
if((ledState1 == HIGH) && (currentMillis - previousMillis1 >= OnTime1))
ledState1 = LOW; // Turn it off
previousMillis1 = currentMillis; // Remember the time
digitalWrite(ledPin1, ledState1); // Update the actual LED
else if ((ledState1 == LOW) && (currentMillis - previousMillis1 >= OffTime1))
ledState1 = HIGH; // turn it on
if((ledState2 == HIGH) && (currentMillis - previousMillis2 >= OnTime2))
ledState2 = LOW; // Turn it off
previousMillis2 = currentMillis; // Remember the time
digitalWrite(ledPin2, ledState2); // Update the actual LED
else if ((ledState2 == LOW) && (currentMillis - previousMillis2 >= OffTime2))
ledState2 = HIGH; // turn it on
the second base code is
int A = 7;
int B = 8;
int C = 9;
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
  • Turn on the given LED
  • @paramledNum LED to turn on (1..6)
void setLED(int ledNum)
if(ledNum == 1)
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, INPUT);
digitalWrite(A, HIGH);
digitalWrite(B, LOW);
if(ledNum == 2)
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, INPUT);
digitalWrite(A, LOW);
digitalWrite(B, HIGH);
if(ledNum == 3)
pinMode(A, INPUT);
pinMode(B, OUTPUT); // changed to input to trigger tri state.
pinMode(C, OUTPUT);
digitalWrite(C, LOW);
if(ledNum == 4)
pinMode(A, INPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
digitalWrite(C, HIGH);
if(ledNum == 5)
pinMode(A, OUTPUT);
pinMode(B, INPUT);
pinMode(C, OUTPUT);
if(ledNum == 6)
pinMode(A, OUTPUT);
pinMode(B, INPUT);
pinMode(C, OUTPUT);
digitalWrite(C,HIGH);
for(;:wink:
setLED(1);
setLED(2);
delay(200);
setLED(3);
delay(200);
setLED(4);
delay(200);
setLED(5);
delay(200);
setLED(6);
delay(200);
Combine (copy & paste from one into the other) the stuff before setup(), combne the stuff in setup(), combine the stuff in loop(), copy the functions.
Take care of any duplicate names, duplicate pin numbers, duplicate variable names. See if compiles & operates the way you want it to.
Start by reading this read this before posting a programming question and edit your post to include code tags. Then describe what each program does and what you want the combined program to do.
