I am trying to combine 5 bits of code for an environmental monitor
I have a
DHT11 Sensor
LCD Screen
Utrasonic sensor
LDR
Servo
I am trying to have a breadboard and UNO board powering these sensors so when the temperature in a room goes above 25 degrees celcius the window will open. My code I have for this so far is in seperate parts these are
#include <dht.h>
dht DHT;
#define DHT11_PIN 7
void setup(){
int chk = DHT.read11(DHT11_PIN);
Serial.print("Temperature = ");
Serial.println(DHT.temperature);
Serial.print("Humidity = ");
Serial.println(DHT.humidity);
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16, 2);
lcd.print("hello, world!");
lcd.clear();
Adafruit Arduino - Lesson 14. Sweep
#include <Servo.h>
int servoPin = 9;
Servo servo;
int angle = 0; // servo position in degrees
servo.attach(servoPin);
// scan from 0 to 180 degrees
for(angle = 0; angle < 180; angle++)
servo.write(angle);
delay(15);
// now scan back from 180 to 0 degrees
for(angle = 180; angle > 0; angle--)
servo.write(angle);
delay(15);
#include "NewPing.h"
#define TRIGGER_PIN 12 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 11 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
delay(500); // Wait 500ms between pings (about 2 pings/sec). 29ms should be the shortest delay between pings.
unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
Serial.print("Ping: ");
Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
Serial.println("cm");
and I also am wondering what code I would need to incorporate LDR into this?
Any help is much appreciated!
