Combining codes
Hi I have 2 separate codes that I want to combine!
First code if for toggle button to turn LEDs on/off. Second code is for LEDs to turn on when LDR senses darkness.
I wish for my code to be able to turn LEDs on when its dark but can also be turned on/off with toggle button. Any help would be appreciated!
const int buttonPin = 2;    //  button is connected to pin
bool buttonState = 0;       // variable to hold the button state
bool Mode = 0;              // What mode is the light in?
  pinMode(buttonPin, INPUT_PULLUP);    // Set the switch pin as input
  pinMode(LED_BUILTIN, OUTPUT);
  if (!digitalRead(buttonPin)) // cheks if button is pressed (cheks if it's LOW, becouse PULLUP inverts signal: LOW = button pressed)
    if (!buttonState) // same as: (buttonState == false) ---I made it a bit compact, but it may be confusinf to you
      buttonState = true;
      Mode = !Mode; // this inverts button mode: If Mode was True - it will make it False and viseversa
  else buttonState = false;
  // blink LED
  digitalWrite(LED_BUILTIN, Mode); // remember: TRUE = HIGH = 1 and FALSE = LOW = 0 (You can use whatever You like)
  delay(5);
//set pin numbers
//const won't change
const int ledPin = 13;   //the number of the LED pin
const int ldrPin = A0;  //the number of the LDR pin
  pinMode(ledPin, OUTPUT);  //initialize the LED pin as an output
  pinMode(ldrPin, INPUT);   //initialize the LDR pin as an input
  int ldrStatus = analogRead(ldrPin);   //read the status of the LDR value
  //check if the LDR status is <= 10
  //if it is, the LED is HIGH
   if (ldrStatus <=10) {
    digitalWrite(ledPin, HIGH);               //turn LED on
    Serial.println("LDR is DARK, LED is ON");
  else {
    digitalWrite(ledPin, LOW);          //turn LED off
    Serial.println("---------------");
How would I possibly combine these? Thank you in advance!
This Simple Merge Demo may help.
Before trying to merge the programs go through each of them carefully to make sure they are not trying to use the same resource - for example an I/O pin. If you find conflicts change something in one of the separate programs and make sure it still works with the change.
...R
