Combining Codes
I am currently working on a project that involves using 4 sensors and one GPS Module
This is a breakdown of the sensors I am using:
-SPEC Sensor Ozone sensor
-Adafruit Anemometer 1733 (Analog Sensor)
-Honeywell 2.5PM sensor (HPMA115S0)
-Adafruit MPL3115A2 - I2C Barometric Pressure/Altitude/Temperature Sensor
-Adafruit Ultimate GPS Breakout - 66 channel w/10 Hz updates - Version 3
I am using an inland mega 2560 Board
So far all the sensors are working individually and getting accurate readings. I have managed to get the Pressure and GPS working together as well. However, as soon as I start adding the other codes I get the error message that “xxxx was not declared in this scope”. Which I thought was strange since the code worked perfectly individually. When combining code is there anything I need to pay attention to except for adding the setup into the setup and the loop sections in the loop sections?
This is the example code that was working for the pressure and GPS sensor.
  This is a library for the BMP3XX temperature & pressure sensor
  Designed specifically to work with the Adafruit BMP388 Breakout
  ----> http://www.adafruit.com/products/3966
  These sensors use I2C or SPI to communicate, 2 or 4 pins are required
  to interface.
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing products
  from Adafruit!
  Written by Limor Fried & Kevin Townsend for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
//Barometric Pressure
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BMP3XX.h"
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 10
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BMP3XX bmp; // I2C
//Adafruit_BMP3XX bmp(BMP_CS); // hardware SPI
//Adafruit_BMP3XX bmp(BMP_CS, BMP_MOSI, BMP_MISO,  BMP_SCK);
//GPS
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);//TX 10, RX 11
Adafruit_GPS GPS(&mySerial);
#define GPSECHO  true
boolean usingInterrupt = false;
void useInterrupt(boolean);
  //GPS
  GPS.begin(9600);
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
  GPS.sendCommand(PGCMD_ANTENNA);
  useInterrupt(true);
  while (!Serial);
  Serial.println("test");
  if (!bmp.begin()) {
    Serial.println("Could not find a valid BMP3 sensor, check wiring!");
    while (1);
  //Pressure
  // Set up oversampling and filter initialization
  bmp.setTemperatureOversampling(BMP3_OVERSAMPLING_8X);
  bmp.setPressureOversampling(BMP3_OVERSAMPLING_4X);
  bmp.setIIRFilterCoeff(BMP3_IIR_FILTER_COEFF_3);
  //bmp.setOutputDataRate(BMP3_ODR_50_HZ);
  //PM
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
#ifdef UDR0
  if (GPSECHO)
    if (c) UDR0 = c;
    // writing direct to UDR0 is much much faster than Serial.print
    // but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    usingInterrupt = true;
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
//PM
// in case you are not using the interrupt above, you'll
  // need to 'hand query' the GPS, not suggested :(
  if (! usingInterrupt) {
    // read data from the GPS in the 'main loop'
    if (GPSECHO)
      if (c) Serial.print(c);
      //PM
  // if a sentence is received, we can check the checksum, parse it...
  if (GPS.newNMEAreceived()) {
    // a tricky thing here is if we print the NMEA sentence, or data
    // we end up not listening and catching other sentences!
    // so be very wary if using OUTPUT_ALLDATA and trytng to print out data
    //Serial.println(GPS.lastNMEA());   // this also sets the newNMEAreceived() flag to false
    if (!GPS.parse(GPS.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
  // if millis() or timer wraps around, we'll just reset it
  if (timer > millis())  timer = millis();
  // approximately every 2 seconds or so, print out the current stats
  if (millis() - timer >4000) {
    timer = millis(); // reset the timer
    Serial.print("GPS Module");
    Serial.print("\nTime: ");
    Serial.print(GPS.hour, DEC); Serial.print(':');
    Serial.print(GPS.minute, DEC); Serial.print(':');
    Serial.print(GPS.seconds, DEC); Serial.print('.');
    Serial.println(GPS.milliseconds);
    Serial.print("Date: ");
    Serial.print(GPS.day, DEC); Serial.print('/');
    Serial.print(GPS.month, DEC); Serial.print("/20");
    Serial.println(GPS.year, DEC);
    Serial.print("Fix: "); Serial.print((int)GPS.fix);
    Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
    if (GPS.fix) {
      Serial.print("Location: ");
      Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
      Serial.print(", ");
      Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
      Serial.print("Location (in degrees, works with Google Maps): ");
      Serial.print(GPS.latitudeDegrees, 4);
      Serial.print(", ");
      Serial.println(GPS.longitudeDegrees, 4);
      Serial.print("Speed (knots): "); Serial.println(GPS.speed);
      Serial.print("Angle: "); Serial.println(GPS.angle);
      Serial.print("Altitude: "); Serial.println(GPS.altitude);
      Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
      Serial.print("------------------------------------------------------");
      Serial.println("----------------------------------------");
  if (! bmp.performReading()) {
    Serial.println("Failed to perform reading :(");
    return;
  Serial.println("Pressure Readings");
  Serial.print("Temperature = ");
  Serial.print(bmp.temperature*9/5+32);
  Serial.println(" *F");
  Serial.print("Pressure = ");
  Serial.print(bmp.pressure / 100.0*0.014503773773);
  Serial.println(" psi");
  Serial.print("Approx. Altitude = ");
  Serial.print(bmp.readAltitude(SEALEVELPRESSURE_HPA)*3.28);
  Serial.println(" ft");
  delay(4000);
Any kind of input is much appreciated.
Thank you,
Stephan
Sorry for splitting this up in to two post. The original exceeded the character limit.
this is the example where I get an error when compiling that reads “flush_serial1 was not declared in this scope”, even though when the code is compiled individually no error message is prompted and the sensor is working without any problems.
#include <Wire.h>
#include <SPI.h>
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 10
//GPS edited out to meet character limit
//PM2.5
//Ozone
String SensorSerialNo;
int H2S;
int Temperature;
int RH;
int RawSensor;
int TempDigital;
int RHDigital;
int Days;
int Hours;
int Minutes;
int Seconds;
#define command_delay 500
#define start_delay 2500
String dataString = "";
String responseString = "";
boolean dataStringComplete = 0;
char inChar;
  //GPS
  GPS.begin(9600);
  useInterrupt(true);
  while (!Serial);
  if (!bmp.begin()) {
    while (1);
  //Pressure
  //PM
  //Ozone
  while(!Serial);
  Serial.println("SPEC DGS-H2S sensor demo code!");
  Serial.println("");
  Serial1.begin(9600);
  // Normally, data is returned within one second
  Serial1.setTimeout(1500);
  // reserve 80 bytes for the dataString
  dataString.reserve(80);
  responseString.reserve(150);
  // Wait for sensor
  flush_serial1();
  Serial.println("Resetting sensor");
  SPEC_reset();
  // Print firmware version
  SPEC_show_firmware();
  // EEPROM dump
  SPEC_dump_EEPROM();
  Serial.println(" ");
  Serial.println("STARTING MEASUREMENTS");
#ifdef UDR0
  if (GPSECHO)
    if (c) UDR0 = c;
#endif
  if (v) {
    OCR0A = 0xAF;
//PM
//Pressure Code
//GPS code
//I had to edit out the pressure and GPS code  due to the character limit
      //PM
      //Ozone
      // Do a readout every 10 seconds
      SPEC_Data_read();
      SPEC_parse_data();
      SPEC_print_data();
      delay(10000);
  //Ozone
  void SPEC_Data_read(){
  // First, we do some initialization
  // dataStringComplete is set as "false", as we don't have any valid data received
  // Clear the data string
  dataString = "";
  // Now we trigger a measurement
  //Serial1.print(" ");
  Serial1.print("\r");
  // We wait for the sensor to respond
  dataString = Serial1.readStringUntil('\n');
  //Serial.println(dataString);
 * This function takes the received string and upodates sensor data
void SPEC_parse_data(){
  // Parses the received dataString
  // Data string is comma separated
  // The format of the output is: SN[XXXXXXXXXXXX], PPB [0 : 999999], TEMP [-99:99],
  // RH[0:99], RawSensor[ADCCount], TempDigital, RHDigital, Day[0:99], Hour [0:23],
  // Minute[0:59], Second[0 : 59]\r\n
  // Take a look also at
  // https://stackoverflow.com/questions/11068450/arduino-c-language-parsing-string-with-delimiter-input-through-serial-interfa
  // We look first for the SN
  int idx1 = dataString.indexOf(',');
  SensorSerialNo = dataString.substring(0, idx1);
  int idx2 = dataString.indexOf(',', idx1 + 1);
  // Hint: after comma there's a space - it should be ignored
  String S_gas = dataString.substring(idx1 + 2, idx2);
  H2S = S_gas.toInt();
  int idx3 = dataString.indexOf(',', idx2 + 1);
  String S_temp = dataString.substring(idx2 + 2, idx3);
  Temperature = S_temp.toInt();
  int idx4 = dataString.indexOf(',', idx3 + 1);
  String S_humi = dataString.substring(idx3 + 2, idx4);
  RH = S_humi.toInt();
  int idx5 = dataString.indexOf(',', idx4 + 1);
  String S_raw_gas = dataString.substring(idx4 + 2, idx5);
  RawSensor = S_raw_gas.toInt();
  int idx6 = dataString.indexOf(',', idx5 + 1);
  String S_Tdigital = dataString.substring(idx5 + 2, idx6);
  TempDigital = S_Tdigital.toInt();
  int idx7 = dataString.indexOf(',', idx6 + 1);
  String S_RHdigital = dataString.substring(idx6 + 2, idx7);
  RHDigital = S_RHdigital.toInt();
  int idx8 = dataString.indexOf(',', idx7 + 1);
  String S_Days = dataString.substring(idx7 + 2, idx8);
  Days = S_Days.toInt();
  int idx9 = dataString.indexOf(',', idx8 + 1);
  String S_Hours = dataString.substring(idx8 + 2, idx9);
  Hours = S_Hours.toInt();
  int idx10 = dataString.indexOf(',', idx9 + 1);
  String S_Minutes = dataString.substring(idx9 + 2, idx10);
  Minutes = S_Minutes.toInt();
  int idx11 = dataString.indexOf('\r');
  String S_Seconds = dataString.substring(idx10 + 2, idx11);
  Seconds = S_Seconds.toInt();
 * This function prints the sensor data
void SPEC_print_data(){
  Serial.println("********************************************************************");
  Serial.print ("Sensor Serial No. is ");
  Serial.println (SensorSerialNo);
  Serial.print ("O3 level is ");
  Serial.print (H2S);
  Serial.println (" ppb");
  Serial.print ("Temperature is ");
  Serial.print (Temperature *9/5+32, DEC);
  Serial.println (" deg F");
  Serial.print ("Humidity is ");
  Serial.print (RH, DEC);
  Serial.println ("% RH");
  Serial.print ("Sensor is online since: ");
  Serial.print (Days, DEC);
  Serial.print (" days, ");
  Serial.print (Hours, DEC);
  Serial.print (" hours, ");
  Serial.print (Minutes, DEC);
  Serial.print (" minutes, ");
  Serial.print (Seconds, DEC);
  Serial.println (" seconds");
  Serial.println ("Raw Sensor Data");
  Serial.print ("Raw gas level: ");
  Serial.println (RawSensor);
  Serial.print ("Temperature digital: ");
  Serial.println (TempDigital);
  Serial.print ("Humidity digital: ");
  Serial.println (RHDigital);
  Serial.println ("");
 * EEPROM dump
void SPEC_dump_EEPROM(){
  Serial1.print("e");
  // You can uncomment this line if you wish
  for (int i=0; i<20; i++){
    responseString = Serial1.readStringUntil('\n');
    Serial.println(responseString);
void SPEC_reset(){
  Serial1.print("r");
void SPEC_show_firmware(){
  Serial1.print("f");
  Serial.print("Sensor firmware version is ");
  Serial.println("");
  delay(400);
void flush_serial1(){
  // Do we have data in the serial buffer?
  // If so, flush it
  if (Serial1.available() > 0){
    Serial.println ("Flushing serial buffer...");
    while(1){
      inChar = (char)Serial1.read();
      delay(10);
      Serial.print(inChar);
      if (inChar == '\n') break;
    Serial.println (" ");
    Serial.println ("Buffer flushed!");
Move your function flush_serial1 before the setup
