I am working on a project where I need an ethernet connection and some relays.
I currently have the following hardware:
Arduino R3
Arduino 4 Relays Shield
Arduino Ethernet 2 Shield
Now I saw (too late) in the docs for the ethernet shield that it uses pin 4 for the SD connection. This clashes with the pins used for one of the four relays on the other shield.
So I am wondering if there are some ways around this? I don't need the SD functionality, but it doesn't seem like there is a straightforward way to accomplish that. My other idea was to mutilate the relay pins in such a way to connect the 4 pin from the relay shield to another free pin.
Another alternative would be to get additional relays to use separately, but I only need the four
Look at the schematic. Does pin 4 connect to anything on the Ethernet board when there is no card inserted? I see it go to pin 2 of IC3, it's always an input so I don't think it would interfere with a relay output.
If I reverse the operations, so first initialize the Ethernet connection, then setup the pinMode, it does seem to work, but requests made have no contents and receiving doesn't seem to work either. So I assume there is some dependency also for the Ethernet functionality somewhere on pin 4.
