combining GPS code and PID tuning code into one sketch
I have a completed sketch for an autonomous GPS navigation car. Since the GPS module is not very accurate, I was thinking about using PID to get rid of the cars deviation.
I have one sketch for the GPS car and another sketch for the PID tuning.
How do I combine these two programs into one program? The code for each program is below.
/* GPS Car v0.1 by Eric Barch (ttjcrew.com) */
#include <nmea.h>
#include <Servo.h>
#undef abs
#undef round
int wpt = 0;
float dest_latitude;
float dest_longitude;
NMEA gps(GPRMC); // GPS data connection to GPRMC sentence typesss
/* BEGIN EDITABLE CONSTANTS SECTION */
//These define the positions for your steering servo
#define CENTER_SERVO 95
#define MAX_LEFT_SERVO 85
#define MAX_RIGHT_SERVO 108
//When the car is within this range (meters), move to the next waypoint
#define WPT_IN_RANGE_M 12
//These pins are your h-bridge output. If the car is running in reverse, swap these
#define MOTOR_OUTPUT_ONE 5
#define MOTOR_OUTPUT_TWO 9
#define Motor_1 10
#define Motor_2 11
/* DEFINE GPS WPTS HERE - Create more cases as needed */
void trackWpts() {
switch(wpt) {
case 0:
dest_latitude = 40.756054;
dest_longitude = -73.986951;
case 1:
dest_latitude = 37.775206;
dest_longitude = -122.419209;
default:
dest_latitude = 0;
dest_longitude = 0;
if (gps.gprmc_distance_to(dest_latitude,dest_longitude,MTR) < WPT_IN_RANGE_M)
wpt++;
/* END EDITABLE CONSTANTS SECTION */
Servo steering;
float dir; // relative direction to destination
int servo_pos = CENTER_SERVO;
Serial.begin(4800);
pinMode(MOTOR_OUTPUT_ONE, OUTPUT);
pinMode(MOTOR_OUTPUT_TWO, OUTPUT);
steering.attach(3);
trackWpts();
trackGPS();
void trackGPS() {
if (dest_latitude != 0 && dest_longitude != 0)
if (Serial.available() > 0 ) {
char c = Serial.read();
if (gps.decode(c)) {
// check if GPS positioning was active
if (gps.gprmc_status() == 'A') {
// calculate relative direction to destination
dir = gps.gprmc_course_to(dest_latitude, dest_longitude) - gps.gprmc_course();
if (dir < 0)
dir += 360;
if (dir > 180)
dir -= 360;
if (dir < -75)
hardLeft();
else if (dir > 75)
hardRight();
driveToTarget();
else //No GPS Fix...Wait for signal
stop();
stop();
void driveStraight() {
steering.write(CENTER_SERVO);
digitalWrite(MOTOR_OUTPUT_ONE, LOW);
digitalWrite(MOTOR_OUTPUT_TWO, HIGH);
analogWrite(Motor_1, 50);
analogWrite(Motor_2, 50);
Serial.println("Driving straight...");
void driveToTarget() {
servo_pos = map(dir, -75, 75, MAX_LEFT_SERVO, MAX_RIGHT_SERVO);
steering.write(servo_pos);
Serial.print("Driving at ");
Serial.print(dir);
Serial.print(". - ");
Serial.print(gps.gprmc_distance_to(dest_latitude,dest_longitude,MTR));
Serial.print("m to go");
Serial.print("\n");
void hardLeft() {
steering.write(MAX_LEFT_SERVO);
Serial.print("Driving hard left. - ");
Serial.print("\n");
void hardRight() {
steering.write(MAX_RIGHT_SERVO);
Serial.print("Driving hard right. - ");
Serial.print("\n");
void stop() {
digitalWrite(MOTOR_OUTPUT_ONE, HIGH);
Serial.print("Stopped.");
Serial.print("\n");
#include <PID_v1.h>
#define PIN_INPUT 0
#define PIN_OUTPUT 3
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Define the aggressive and conservative Tuning Parameters
double aggKp=4, aggKi=0.2, aggKd=1;
double consKp=1, consKi=0.05, consKd=0.25;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
//initialize the variables we're linked to
Input = analogRead(PIN_INPUT);
Setpoint = 100;
//turn the PID on
myPID.SetMode(AUTOMATIC);
double gap = abs(Setpoint-Input); //distance away from setpoint
if (gap < 10)
{ //we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKP, consKi, consKd);
//we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
analogWrite(PIN_OUTPUT, Output);
Using PID to correct GPS coordinates is... interesting.
By "interesting", I mean "not possible." PID uses feedback (current state) and history (previous states) to get to a desired state. With an inaccurate GPS, you don't really know your current and previous states because they're not accurate.
Kalman Filtering can use multiple inaccurate positions, received over time, to produce a more-accurate estimate of the current position. The more measurements you have, the better the improvement. For example, adding IMU, compass (heading) or odometer (speed) data can help reduce the inaccurate GPS speed and heading data... which can improve your position estimate. Some GPS devices even have built-in support for automotive speed and steering sensor data.
Autonomous navigation is a huge subject, so a Google search will provide more info than you can ever read. Ardupilot might be one place you could start.
Cheers,
/dev
ok,
so are you suggesting to use kalman filtering and IMU together, and that the IMU would respond to the readings of filter?
what would happen if I used PID in this situation?
thanks
so are you suggesting to use kalman filtering and IMU together?
I am suggesting that you read about Kalman Filtering. GPS data, IMU data, motor data, etc. are inputs to a Kalman Filter. The Kalman Filter would output a more-accurate position/speed/heading and error estimate.
...and that the IMU would respond to the readings of filter?
You need to read about IMUs, too.
Nothing. You should also read about PID, because you keep using that word.
:-\ With waypoints in New York City and San Francisco, I think you have a ways to go, in so many ways.
Cheers,
/dev
