combining I2C and SMBUS
I have 2 sensors one use I2C and the other use SMBUS, i know SMBUS is a derivative or subversion of I2C but i was wondering if both can be connected to the same interface (PIN) or i need to use 2 I2C interfacess?
by the way, both use 100khz.
I'm not sure if this is the right place to ask my question but i hope i can get my answer here.
thank you.
As SMbus is a subset of I2C this should work. You have to take more care about voltages, that both sensors run the same voltage on the bus or at least are tolerant for the voltage you plan to run the bus on.
