I just wanted to know if, on Arduino MEGA 2560, combining I2C and SPI buses would create problems of communication ?
I will use 1 device on I2C (DS1307 RTC) and 1 device on SPI (SPI EEPROM).
Thanks !
Thanks !
Trying to combine the buses will create problems. Using the independent buses at the same time should not.
Just collect all the data from one bus before trying to send it on the other bus.
There should be no problem.
I have the same DS1307 RTC, an EEPROM, digital compass, my new LSM303 3d compass/accelerometer all working on the same Mega1280 I2C bus.
On the SPI bus I have an MPL115A barometer.
Only thing I’ve had SPI hassles with is SD cards.
I have yet to read or write squeak to a memory card, but my barometer works great!
Hey, thanks for the fasts answers !
Sorry if i wasn't clear enough in my verbs ... :grin:
What i will basically do is : - At start, READ EEPROM over SPI to gather previously collected/updated data (and from time to time, WRITING new values) - From time to time, reading the DATE/TIME on the DS1307 which will be connected over the I2C bus. (Sometimes updating the values through serial/lcd and buttons)
That's all.
There will never be data coming from one bus and going to the other concurrently !
The one "gotcha" to beware of is when accessing either bus in an interrupt routine - if you do this then all use of the relevant bus in the rest of the code has to be done with interrupts disabled. When a library uses one of these busses you won't know if it plays safe like this so you'll have to avoid using the bus in an interrupt routine.
The hardware for I2C and SPI busses is entirely independent and you can use them simultaneously if you chose...
There is another issue with SPI and multiple devices. Different devices might want different clock speeds or polarity settings and you have to reconfigure the SPI hardware whenever switching from one device to another (as well as using different pins for slave-select of course). Again libraries using SPI may not have support for this, making life tedious.
hello everyone!
i am new to this arduino environment!
Recently i purchased an arducam 5mp!
i tried it with arduino mega 2560 and i got decent results, i used the arducam libraries to get the image data.
i ran a separate arducam.exe application in order to see my images.
When i chose my continuous burst option there was a time lag between each images.
so i thought of using arduino due!
But i am not able to initialise SPI and i2c communication when i use due.
(ERROR:
SPI INTERFACE ERROR
OV5642 not detected(i2c communication))
I searches alot and didnt get any answer.
Can some one help me out pls?
this is the code which i use
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include “memorysaver.h”
#include “ov5642_regs.h”
#define BMPIMAGEOFFSET 66
// set pin 10 as the slave select for the digital pot:
const int CS = 10;
bool is_header = false;
int mode = 0;
uint8_t start_capture = 0;
const char bmp_header[BMPIMAGEOFFSET] PROGMEM =
0x42, 0x4D, 0x36, 0x58, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x28, 0x00,
0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x03, 0x00,
0x00, 0x00, 0x00, 0x58, 0x02, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0xE0, 0x07, 0x00, 0x00, 0x1F, 0x00,
0x00, 0x00
ArduCAM myCAM(OV5642, CS);
uint8_t vid, pid;
uint8_t temp;
#if defined (AVR)
Wire.begin();
#endif
#if defined(arm)
Wire1.begin();
#endif
Serial.println(“ArduCAM Start!”);
// set the CS as an output:
pinMode(CS, OUTPUT);
// initialize SPI:
SPI.begin();
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
//Serial.println(temp);
if (temp != 0x55)
Serial.println(“SPI interface Error!”);
//while(1);
//Check if the camera module type is OV5642
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x42))
Serial.println(“Can’t find OV5642 module!”);
Serial.println(“OV5642 detected.”);
//Change to JPEG capture mode and initialize the OV5642 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, 0x00);
uint8_t temp, temp_last;
if (Serial.available())
temp = Serial.read();
switch (temp)
case 0:
myCAM.OV5642_set_JPEG_size(OV5642_320x240);
case 1:
myCAM.OV5642_set_JPEG_size(OV5642_640x480);
case 2:
myCAM.OV5642_set_JPEG_size(OV5642_1280x720);
case 3:
myCAM.OV5642_set_JPEG_size(OV5642_1920x1080);
case 4:
myCAM.OV5642_set_JPEG_size(OV5642_2048x1563);
case 5:
myCAM.OV5642_set_JPEG_size(OV5642_2592x1944);
case 0x10:
mode = 1;
start_capture = 1;
Serial.println(“CAM start single shoot.”);
case 0x11:
myCAM.InitCAM();
case 0x20:
mode = 2;
start_capture = 2;
Serial.println(“CAM start contrues shoots.”);
case 0x30:
mode = 3;
start_capture = 3;
case 0x31:
myCAM.set_format(BMP);
myCAM.InitCAM();
myCAM.clear_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
myCAM.wrSensorReg16_8(0x3818, 0x81);
myCAM.wrSensorReg16_8(0x3621, 0xA7);
default:
if (mode == 1)
if (start_capture == 1)
myCAM.flush_fifo();
//Start capture
myCAM.start_capture();
start_capture = 0;
if (myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK))
Serial.println(“CAM Capture Done!”);
read_fifo_burst(myCAM);
//Clear the capture done flag
else if (mode == 2)
while (1)
if (temp == 0x21)
start_capture = 0;
mode = 0;
Serial.println(“CAM stop continuous shoots!”);
if (start_capture == 2)
myCAM.flush_fifo();
//Start capture
start_capture = 0;
uint32_t length = 0;
length = myCAM.read_fifo_length();
if ((length >= 524288) | (length == 0))
start_capture = 2;
continue;
myCAM.CS_LOW();
myCAM.set_fifo_burst();//Set fifo burst mode
//SPI.transfer(0x00);
length–;
while ( length-- )
temp_last = temp;
temp = SPI.transfer(0x00);
if (is_header == true)
Serial.write(temp);
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
Serial.write(temp_last);
Serial.write(temp);
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
delayMicroseconds(12);
myCAM.CS_HIGH();
start_capture = 2;
is_header = false;
else if (mode == 3)
if (start_capture == 3)
//Flush the FIFO
myCAM.flush_fifo();
//Start capture
start_capture = 0;
if (length >= 524288 ) // 512kb
Serial.println(“Over size.”);
return;
if (length == 0 ) //0 kb
Serial.println(“Size is 0.”);
return;
myCAM.CS_LOW();
Serial.write(0xFF);
Serial.write(0xAA);
for (temp = 0; temp < BMPIMAGEOFFSET; temp++)
Serial.write(pgm_read_byte(&bmp_header[temp]));
SPI.transfer(0x00);
char VH, VL;
int i = 0, j = 0;
for (i = 0; i < 240; i++)
for (j = 0; j < 320; j++)
VH = SPI.transfer(0x00);;
VL = SPI.transfer(0x00);;
Serial.write(VL);
Serial.write(VH);
Serial.write(0xBB);
Serial.write(0xCC);
myCAM.CS_HIGH();
uint8_t read_fifo_burst(ArduCAM myCAM)
Serial.println(length, DEC);
if (length >= 524288) //512 kb
return 0;
return 0;
myCAM.CS_LOW();
SPI.transfer(0x00);//First byte is 0xC0 ,not 0xff
length–;
while ( length-- )
temp_last = temp;
Serial.write(temp);
is_header = true;
Serial.write(temp);
myCAM.CS_HIGH();
is_header = false;
Dj44: Do not hijack threads. Read the rules and post correctly, using code tags.
