Combining Keypad, LCD and Virtual Wire Libraries
At the moment I am creating a project that involves the use of the following libraries:
<Keypad.h>
<LiquidCrystal.h>
<VirtualWire.h>
The project is and LCD Keypad unit which check a combination. Once the correct combination has been entered it transmits a signal telling another box to open.
Here is the code I am using:
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {11, 10, 9, 8}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {16, 15, 14}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
//**************************************Initalizations********************************************
int combination = 1;
int led13 = 13;
void setup(){
  vw_setup(2000);       // Bits per sec
  lcd.begin(16, 2);
  pinMode(led13, OUTPUT);
void loop(){
  char key = keypad.getKey();
  if (key != NO_KEY){
    lcd.print(key);
  switch (key) {
    case '1':
      combination += 1;
    case '2':
      combination *= 2;
    case '3':
      combination += 3;
    case '4':
      combination -= 4;
    case '5':
      combination *= 5;
    case '6':
      combination += 6;
    case '7':
      combination += 7;
    case '8':
      combination += 8;
    case '9':
      combination *= 9;
    case '0':
      combination *= 10;
    case '*':
      lcd.clear();
      lcd.print(combination);
    default:
      delay(10);
    if (combination == 57250)
      const char *msg = "b";
      digitalWrite(13, true); // Flash a light to show transmitting
      vw_send((uint8_t *)msg, strlen(msg));
      vw_wait_tx(); // Wait until the whole message is gone
      digitalWrite(13, false);
      delay(200);
When I put the VirtualWire and LiquidCrystal libraies together they work fine.
When I put the LiquidCrystal and Keypad Libraries together they work fine too.
However when I try to put the LiquidCrystal, Keypad and VirtualWire libraries together the Keypad has trouble operating.
When they are together the following occurs:
  1. On the LCD the Numbers 4,5,6 are repated over and over.
    or
  2. The keys 4,5,6 don't work where as the other keys do
So I am not sure what to do. Does anyone know if these libraries can be used together or not. If they can what can I do to use them together.
Any advice will be helpful
/me
It is possible your Sketch is running out of memory. Which board are you using?
Are you certain that the VirtualWire library does not use a 'hardwire' pin? I seem to remember it being 11 and 12?
Then it is probably a bad idea to use 11 for the keypad library as well.
I am using the Atmega168-20PU chip on a Arduino Diecimila
To: AlphaBeta
Thanks for the help, you were right, pin 12 and pin 11 are used in the virtualwire library. 11 as a reciever and 12 as a transmitter. Even though I was using only the transmitter program the library still set pin 11 as a reciever pin. Now I have reporgramed it so that the keypad doesn't uses that leg anymore.
Thank you so much
from /me
To: Coding Badly
Thanks for the help!
