Combining led blink and fade (PWM)
Hi!
I have tried this excellent code from UKHeliBob with some modifications
UKHeliBob:
Here is an extended example of a state machine controlling LEDs
const byte ledPins[] = {5, 6, 9, 10};
byte LEDCOUNT = sizeof(ledPins) / sizeof(ledPins[0]);
byte ledIndex = 0;
const unsigned long FIVESECS = 5000;
unsigned long currentTime;
unsigned long startTime;
enum states
 ALL_FADE_UP_TOGETHER,
 ALL_ON_FOR_5_SECS,
What I want:
Im am running the machine all the time and by pass state "Do nothing";
  1. ALL_FADE_UP_TOGETHER,
  2. ALL_ON_FOR_5_SECS,
  3. ALL_FADE_DOWN_TOGETHER,
  4. ALL_OFF_FOR_5_SECS,
    No. 1 again and so on...
What happens:
Because the pwmLevel in state "ALL_FADE_DOWN_TOGHETER" is static when arduino runs the program second time it becomes 256, third 257 etcetera (or in my case -1, -2, depending on my connections).
I have tried
different IF-statements but gets a small flash before fading down.
Maybe there is standard solution to this?
   case ALL_FADE_DOWN_TOGETHER:
      //    case ALL_FADE_UP_TOGETHER:
        static int pwmLevel = 255;
        static int pwmIncrement = 1;
        unsigned long period = 7;  // 7 egen
        if (currentTime - startTime >= period)
          if (pwmLevel == -1)
            Serial.println("Fade down level -1: ");
            Serial.println(pwmLevel);
            pwmLevel = 255;
          setPwmLevelForAllLeds(pwmLevel);
          startTime = millis();
          Serial.println("Fade down - period: ");
          pwmLevel -= pwmIncrement;
          if (pwmLevel == 0) // original <=
            setPwmLevelForAllLeds(0);   //all off
            currentState = ALL_OFF_FOR_5_SECS;
            startTime = currentTime;
      break;
Best Regards Johan
