Combining led blink and fade (PWM)
Thank you for answer!
This is my code right now.
Maybe a global variable is the best?
//https://forum.arduino.cc/index.php?topic=548353.msg3740954#msg3740954
const byte ledPins[] = {10};
byte LEDCOUNT = sizeof(ledPins) / sizeof(ledPins[0]);
byte ledIndex = 0;
const unsigned long FIVESECS = 5000;
const unsigned long OFFSECS = 5000;
unsigned long currentTime;
unsigned long startTime;
enum states
  ALL_FLASH,
  ALL_FADE_UP_TOGETHER,
  ALL_ON_FOR_5_SECS,
  ALL_OFF_FOR_5_SECS,
  ALL_FADE_DOWN_TOGETHER,
  ALL_FADE_UP_DOWN_IN_SEQUENCE,
  DO_NOTHING
byte currentState = ALL_FLASH;
  for (int pin = 0; pin < LEDCOUNT; pin ++)
    pinMode(ledPins[pin], OUTPUT);
    digitalWrite(ledPins[pin], LOW);
  Serial.println("Flash all up together");
  currentTime = millis();
  switch (currentState)
    case ALL_FLASH:
        static int pwmLevel = 255;
        /*  static int pwmIncrement = -255;
          unsigned long period = 20;
          if (currentTime - startTime >= period)
        Serial.println("All Flash: ");
        Serial.println(pwmLevel);
        setPwmLevelForAllLeds(pwmLevel);
        startTime = millis();
        //  pwmLevel += pwmIncrement;
        if (pwmLevel == 255)
          setPwmLevelForAllLeds(0);
          currentState = ALL_ON_FOR_5_SECS;
          startTime = currentTime;
          setPwmLevelForAllLeds(255);   //all on
          Serial.println("All ON  5 seconds");
      break;
    case ALL_FADE_UP_TOGETHER:
        static int pwmLevel = 0;
        static int pwmIncrement = +1;
          if (pwmLevel >= 255)
            Serial.println("Waiting 5 seconds");
      break;
    case ALL_ON_FOR_5_SECS:
      if (currentTime - startTime >= FIVESECS)
        currentState = ALL_FADE_DOWN_TOGETHER;
        Serial.println("Fading all down together");
      break;
    case ALL_OFF_FOR_5_SECS:
      if (currentTime - startTime >= OFFSECS)
        Serial.println("All flash");
      break;
    case ALL_FADE_DOWN_TOGETHER:
      //    case ALL_FADE_UP_TOGETHER:
        static int pwmIncrement = 1;
        unsigned long period = 7;  // 7 egen
          if (pwmLevel == -1)
            Serial.println("Fade down level -1: ");
            pwmLevel = 255;
          Serial.println("Fade down - period: ");
          pwmLevel -= pwmIncrement;
          if (pwmLevel == 0) // original <=
            setPwmLevelForAllLeds(0);   //all off
            currentState = ALL_OFF_FOR_5_SECS;
      break;
    case ALL_FADE_UP_DOWN_IN_SEQUENCE:
        static unsigned long startTime;
        static int pwmIncrement = -1;
        unsigned long period = 5;
          analogWrite(ledPins[ledIndex], pwmLevel);
          if (pwmLevel <= 0)
            pwmIncrement *= -1;
            pwmLevel = 255;
            analogWrite(ledPins[ledIndex], pwmLevel);  //make sure that the  LED is off
            pwmIncrement *= -1;
            ledIndex++;
            if (ledIndex >= LEDCOUNT)
              currentState = DO_NOTHING;
              Serial.println("Doing nothing forever");
          break;
    case DO_NOTHING:
        break;
void setPwmLevelForAllLeds(byte pwmLevel)
  for (int ledIndex = 0; ledIndex < LEDCOUNT; ledIndex++)
