I have dual L298N HBridge that is rated for 2A per line, like the one shown below. I also have DC motor that draws 2.5A, even more at startup. So I had idea to combine lines to split load evenly between them, like so:
Arduino to HBridge:
pin1 -> [ENA + ENB]
pin2 -> [IN1 + IN3]
pin3 -> [IN2 + IN4]
HBridge to motor:
[OUT1 + OUT3] -> motor +
[OUT2 + OUT4] -> motor -
Would this work, or that's secret formula for magic blue smoke?
The ancient, inefficient L298 should not be considered for anything but the smallest motors. Use a modern motor driver that can handle the stall current of your motor.
Yes, your proposal will work to increase the current output.
However two plus two doesn't always equal four. The datasheet probably says that the maximum on one channel is only possible with the other channel undriven.
I know that now, but didn't when I bought it. I'm very new to Arduino and electronics. If/when it burns I'll get another part, have my eyes on a nice 43A driver.
jremington:
As much as 5 to 10 times more. Look up the actual value.
Actually can't, it's a car window motor from a scrapyard, with no readable markings.
MorganS:
Excellent, off to the laboratory! Will keep fire extinguisher handy
Be aware that the doubling up trick won't work with stepper drivers like the DRV8825, it will probably blow them up... The L298N is a very simple device by comparison, just a current amplifier.
