Combining Multiple Scripts?
I've been trying to combine these two scripts for two days however, cannot for the life of me just get the dustDensity to save to my database both scripts work absolutely fine individually.
This script connects to my local wifi and saves data to a local database
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
int Led_OnBoard = 2;                  // Initialize the Led_OnBoard
const char* ssid = "Lots of Security";                  // Your wifi Name
const char* password = "Password";          // Your wifi Password
const char *host = "192.168.1.64"; //Your pc or server (database) IP, example : 192.168.0.0 , if you are a windows os user, open cmd, then type ipconfig then look at IPv4 Address.
  pinMode(Led_OnBoard, OUTPUT);       // Initialize the Led_OnBoard pin as an output
  WiFi.mode(WIFI_OFF);        //Prevents reconnection issue (taking too long to connect)
  WiFi.mode(WIFI_STA);        //This line hides the viewing of ESP as wifi hotspot
  WiFi.begin(ssid, password);     //Connect to your WiFi router
  Serial.println("");
  Serial.print("Connecting");
  // Wait for connection
    digitalWrite(Led_OnBoard, LOW);
    delay(250);
    Serial.print(".");
    digitalWrite(Led_OnBoard, HIGH);
    delay(250);
  //If connection successful show IP address in serial monitor
  Serial.println("");
  Serial.println("Connected to Network/SSID");
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());  //IP address assigned to your ESP
  HTTPClient http;    //Declare object of class HTTPClient
  String LdrValueSend, postData;
  int ldrvalue=analogRead(A0);  //Read Analog value of LDR
  LdrValueSend = String(ldrvalue);   //String to interger conversion
  //Post Data
  postData = "ldrvalue=" + LdrValueSend;
  http.begin("http://192.168.1.64/Nodemcu_db_record_view/InsertDB.php");              //Specify request destination
  http.addHeader("Content-Type", "application/x-www-form-urlencoded");    //Specify content-type header
  int httpCode = http.POST(postData);   //Send the request
  String payload = http.getString();    //Get the response payload
  //Serial.println("LDR Value=" + ldrvalue);
  Serial.println(httpCode);   //Print HTTP return code
  Serial.println(payload);    //Print request response payload
  Serial.println("LDR Value=" + LdrValueSend);
  http.end();  //Close connection
  delay(4000);  //Here there is 4 seconds delay plus 1 second delay below, so Post Data at every 5 seconds
script 2 which reads my sensor
int dustPin = A0; // dust sensor
int ledPin = D2;
float voltsMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
  Serial.begin(57600);
  pinMode(ledPin,OUTPUT);
  digitalWrite(ledPin,LOW); // power on the LED
  delayMicroseconds(280);
  voltsMeasured = analogRead(dustPin); // read the dust value
  delayMicroseconds(40);
  digitalWrite(ledPin,HIGH); // turn the LED off
  delayMicroseconds(9680);
  //measure your 5v and change below
  calcVoltage = voltsMeasured * (3.3 / 1024.0);
  dustDensity = 0.17 * calcVoltage - 0.1;
  Serial.println("GP2Y1010AU0F readings");
  Serial.print("Raw Signal Value = ");
  Serial.println(voltsMeasured);
  Serial.print("Voltage = ");
  Serial.println(calcVoltage);
  Serial.print("Dust Density = ");
  Serial.println(dustDensity); // mg/m3
  Serial.println("");
Instead of saving the ldrvalue value to my database i'd like to save the dustDensity. Can anyone help please?
Do you have a version of the combined sketch?
Here's both scripts together which compile fine
int ledPin = 12;                // Initialize the Led Pin
int dustPin = A0; // dust sensor pin
  pinMode(ledPin, OUTPUT);       // Initialize the Led_OnBoard pin as an output
  Serial.println("");
    digitalWrite(ledPin, LOW);
    delay(250);
    Serial.print(".");
    digitalWrite(ledPin, HIGH);
    delay(250);
  Serial.println("");
  Serial.println("");
  //Post Data
It would be a rather filthy hack, but I suspect that changing this:
To
  LdrValueSend = String(dustDensity);   //Float to String conversion
Would do it. It is ok that your postData still says ldrValue?
Start with this sketch:
  setup1();
  setup2();
  loop1();
  loop2();
For the two sketches, add a New Tab using the little down-arrow menu on the right end of the tabs bar. I named them "Sketch1.ino" and "Sketch2.ino". Copy your two sketches into those new tabs. In "Sketch1.ino" change setup() to setup1() and loop() to loop1(). Similar for "Sketch2.ino". Now the combined sketch will compile.
There is one compile warning but it probably existed before the sketches were combined:
/Users/john/Documents/Arduino/sketch_oct12a/Sketch1.ino: In function 'void loop1()':
/Users/john/Documents/Arduino/sketch_oct12a/Sketch1.ino:57:71: warning: 'bool HTTPClient::begin(String)' is deprecated (declared at /Users/john/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.h:155) [-Wdeprecated-declarations]
Of course if either sketch is written poorly so that, for example, loopX() doesn't return quickly, you may find that your combined sketch is not responsive. Also, if you need data to travel between sketches you may need to use a global variable or have one sketch call functions in the other sketch.
This change compiles without error:
  String DDValueSend, postData;
  extern float dustDensity;
  DDValueSend = String(dustDensity);   // float to String conversion
  //Post Data
  postData = "dustDensity=" + DDValueSend;
  Serial.println("Dust Density Value=" + DDValueSend);
