Combining of 2 Different Codes
How to combine the codes of Incubator Using Arduino with Automatic Temperature and Humidity Control (DHT11) and Heartbeat Sensor?
INCUBATOR CODE:
#include <LiquidCrystal.h>
#include <Servo.h>
#include <dht.h>
#define DHT11 A0
const int ok = A1;
const int UP = A2;
const int DOWN = A3;
const int bulb = A4;
const int vap = A5;
const int rs = 12;
const int en = 11;
const int d4 = 5;
const int d5 = 4;
const int d6 = 3;
const int d7 = 2;
int ack = 0;
int pos = 0;
int sec = 0;
int Min = 0;
int hrs = 0;
int T_threshold = 25;
int H_threshold = 60;
int SET = 0;
int Direction = 0;
boolean T_condition = true;
boolean H_condition = true;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
Servo motor;
dht DHT;
pinMode(ok, INPUT);
pinMode(UP, INPUT);
pinMode(DOWN, INPUT);
pinMode(bulb, OUTPUT);
pinMode(vap, OUTPUT);
digitalWrite(bulb, LOW);
digitalWrite(vap, LOW);
digitalWrite(ok, HIGH);
digitalWrite(UP, HIGH);
digitalWrite(DOWN, HIGH);
motor.attach(7);
motor.write(pos);
lcd.begin(16, 2);
lcd.setCursor(5, 0);
lcd.print("Digital");
lcd.setCursor(4, 1);
lcd.print("Incubator");
delay(1500);
if (SET == 0)
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Set Temperature:");
lcd.setCursor(0, 1);
lcd.print(T_threshold);
lcd.print(" *C");
while (T_condition)
if (digitalRead(UP) == LOW)
T_threshold = T_threshold + 1;
lcd.print(" *C");
delay(200);
if (digitalRead(DOWN) == LOW)
T_threshold = T_threshold - 1;
lcd.print(" *C");
delay(200);
if (digitalRead(ok) == LOW)
delay(200);
T_condition = false;
lcd.clear();
lcd.print("Set Humidity:");
lcd.print(H_threshold);
lcd.print("%");
delay(100);
while (H_condition)
H_threshold = H_threshold + 1;
lcd.print("%");
delay(200);
H_threshold = H_threshold - 1;
lcd.print("%");
delay(200);
delay(200);
H_condition = false;
SET = 1;
ack = 0;
int chk = DHT.read11(DHT11);
switch (chk)
case DHTLIB_ERROR_CONNECT:
ack = 1;
if (ack == 0)
lcd.clear();
lcd.print("Temp:");
lcd.print(DHT.temperature);
lcd.print("Humidity:");
lcd.print(DHT.humidity);
if (DHT.temperature >= T_threshold)
delay(3000);
if (DHT.humidity >= H_threshold)
delay(3000);
digitalWrite(vap, HIGH);
if (DHT.temperature < T_threshold)
delay(3000);
digitalWrite(bulb, HIGH);
if (DHT.humidity < H_threshold)
delay(3000);
sec = sec + 1;
if (sec == 60)
sec = 0;
Min = Min + 1;
if (Min == 60)
Min = 0;
hrs = hrs + 1;
if (hrs == 8 && Min == 0 && sec == 0)
for (pos = 0; pos <= 180; pos += 1)
motor.write(pos);
delay(25);
if (hrs == 16 && Min == 0 && sec == 0)
hrs = 0;
for (pos = 180; pos >= 0; pos -= 1)
motor.write(pos);
delay(25);
if (ack == 1)
lcd.clear();
lcd.print("No Sensor data.");
lcd.print("System Halted.");
HEARTBEAT SENSOR CODE:
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int pulsePin = A0;                 // Pulse Sensor purple wire connected to analog pin A0
int blinkPin = 13;                // pin to blink led at each beat
// Volatile Variables, used in the interrupt service routine!
volatile int BPM;                   // int that holds raw Analog in 0. updated every 2mS
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false;     // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
static boolean serialVisual = true;   // Set to 'false' by Default.  Re-set to 'true' to see Arduino Serial Monitor ASCII Visual Pulse
volatile int rate[10];                      // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0;          // used to determine pulse timing
volatile unsigned long lastBeatTime = 0;           // used to find IBI
volatile int P = 512;                      // used to find peak in pulse wave, seeded
volatile int T = 512;                     // used to find trough in pulse wave, seeded
volatile int thresh = 525;                // used to find instant moment of heart beat, seeded
volatile int amp = 100;                   // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false;      // used to seed rate array so we startup with reasonable BPM
  pinMode(blinkPin, OUTPUT);        // pin that will blink to your heartbeat!
  Serial.begin(300);             // we agree to talk fast!
  interruptSetup();                 // sets up to read Pulse Sensor signal every 2mS
  // IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
  // UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
  //   analogReference(EXTERNAL);
  lcd.begin(16, 2);
  lcd.clear();
//  Where the Magic Happens
  serialOutput();
  if (QS == true) // A Heartbeat Was Found
    // BPM and IBI have been Determined
    // Quantified Self "QS" true when arduino finds a heartbeat
    serialOutputWhenBeatHappens(); // A Beat Happened, Output that to serial.
    QS = false; // reset the Quantified Self flag for next time
  delay(20); //  take a break
void interruptSetup()
  // Initializes Timer2 to throw an interrupt every 2mS.
  TCCR2A = 0x02;     // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
  TCCR2B = 0x06;     // DON'T FORCE COMPARE, 256 PRESCALER
  OCR2A = 0X7C;      // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
  TIMSK2 = 0x02;     // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
  sei();             // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
void serialOutput()
{ // Decide How To Output Serial.
  if (serialVisual == true)
    arduinoSerialMonitorVisual('-', Signal);   // goes to function that makes Serial Monitor Visualizer
    sendDataToSerial('S', Signal);     // goes to sendDataToSerial function
void serialOutputWhenBeatHappens()
  if (serialVisual == true) //  Code to Make the Serial Monitor Visualizer Work
    Serial.print(" Heart-Beat Found ");  //ASCII Art Madness
    Serial.print("BPM: ");
    Serial.println(BPM);
    lcd.print("Heart-Beat Found ");
    lcd.setCursor(1, 1);
    lcd.print("BPM: ");
    lcd.setCursor(5, 1);
    lcd.print(BPM);
    delay(300);
    lcd.clear();
    sendDataToSerial('B', BPM);  // send heart rate with a 'B' prefix
    sendDataToSerial('Q', IBI);  // send time between beats with a 'Q' prefix
void arduinoSerialMonitorVisual(char symbol, int data )
  const int sensorMin = 0;      // sensor minimum, discovered through experiment
  const int sensorMax = 1024;    // sensor maximum, discovered through experiment
  int sensorReading = data; // map the sensor range to a range of 12 options:
  int range = map(sensorReading, sensorMin, sensorMax, 0, 11);
  // do something different depending on the
  // range value:
void sendDataToSerial(char symbol, int data )
  Serial.print(symbol);
  Serial.println(data);
ISR(TIMER2_COMPA_vect) //triggered when Timer2 counts to 124
  cli();                                      // disable interrupts while we do this
  Signal = analogRead(pulsePin);              // read the Pulse Sensor
  sampleCounter += 2;                         // keep track of the time in mS with this variable
  int N = sampleCounter - lastBeatTime;       // monitor the time since the last beat to avoid noise
  //  find the peak and trough of the pulse wave
  if (Signal < thresh && N > (IBI / 5) * 3) // avoid dichrotic noise by waiting 3/5 of last IBI
    if (Signal < T) // T is the trough
      T = Signal; // keep track of lowest point in pulse wave
  if (Signal > thresh && Signal > P)
  { // thresh condition helps avoid noise
    P = Signal;                             // P is the peak
  }                                        // keep track of highest point in pulse wave
  //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
  // signal surges up in value every time there is a pulse
  if (N > 250)
  { // avoid high frequency noise
    if ( (Signal > thresh) && (Pulse == false) && (N > (IBI / 5) * 3) )
      Pulse = true;                               // set the Pulse flag when we think there is a pulse
      digitalWrite(blinkPin, HIGH);               // turn on pin 13 LED
      IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
      lastBeatTime = sampleCounter;               // keep track of time for next pulse
      if (secondBeat)
      { // if this is the second beat, if secondBeat == TRUE
        secondBeat = false;                  // clear secondBeat flag
        for (int i = 0; i <= 9; i++) // seed the running total to get a realisitic BPM at startup
          rate[i] = IBI;
      if (firstBeat) // if it's the first time we found a beat, if firstBeat == TRUE
        firstBeat = false;                   // clear firstBeat flag
        secondBeat = true;                   // set the second beat flag
        sei();                               // enable interrupts again
        return;                              // IBI value is unreliable so discard it
      // keep a running total of the last 10 IBI values
      word runningTotal = 0;                  // clear the runningTotal variable
      for (int i = 0; i <= 8; i++)
      { // shift data in the rate array
        rate[i] = rate[i + 1];                // and drop the oldest IBI value
        runningTotal += rate[i];              // add up the 9 oldest IBI values
      rate[9] = IBI;                          // add the latest IBI to the rate array
      runningTotal += rate[9];                // add the latest IBI to runningTotal
      runningTotal /= 10;                     // average the last 10 IBI values
      BPM = 60000 / runningTotal;             // how many beats can fit into a minute? that's BPM!
      QS = true;                              // set Quantified Self flag
      // QS FLAG IS NOT CLEARED INSIDE THIS ISR
  if (Signal < thresh && Pulse == true)
  { // when the values are going down, the beat is over
    digitalWrite(blinkPin, LOW);           // turn off pin 13 LED
    Pulse = false;                         // reset the Pulse flag so we can do it again
    amp = P - T;                           // get amplitude of the pulse wave
    thresh = amp / 2 + T;                  // set thresh at 50% of the amplitude
    P = thresh;                            // reset these for next time
    T = thresh;
  if (N > 2500)
  { // if 2.5 seconds go by without a beat
    thresh = 512;                          // set thresh default
    P = 512;                               // set P default
    T = 512;                               // set T default
    lastBeatTime = sampleCounter;          // bring the lastBeatTime up to date
    firstBeat = true;                      // set these to avoid noise
    secondBeat = false;                    // when we get the heartbeat back
  sei();                                   // enable interrupts when youre done!
}// end isr
You've got a clash for A0.
Those delays will probably have to go too.
I changed the signal pin of heartbeat sensor from A0 to 8.
int pulsePin = 8;                 // Pulse Sensor purple wire connected to analog pin A0
  lcd.begin(16, 2);
  lcd.clear();
  serialOutput();
void serialOutput()
    lcd.print("BPM: ");
    lcd.print(BPM);
    delay(300);
    lcd.clear();
  // range value:
  if (N > 250)
      if (secondBeat)
          rate[i] = IBI;
    T = thresh;
  if (N > 2500)
}// end isr
