Combining Pixy2 with a Zumo sumo bot
We are trying to add a pixy2 sensor to our Zumo sumo robot so that it can detect a border with its line sensors and chase an object with the pixy2 camera. We can get one to work or the other... but we have been unable to get both to work together. We were told a "while" statement might help us out or changing the pixy2 to I2C but we are still unsuccessful. Any advice you can provide us would be greatly appreciated.
We have included our code here:
// begin license header
// This file is part of Pixy CMUcam5 or "Pixy" for short
// All Pixy source code is provided under the terms of the
// GNU General Public License v2 (http://www.gnu.org/licenses/gpl-2.0.html).
// Those wishing to use Pixy source code, software and/or
// technologies under different licensing terms should contact us at
// cmucam@cs.cmu.edu. Such licensing terms are available for
// all portions of the Pixy codebase presented here.
// end license header
#include <Pixy2.h>
#include <PIDLoop.h>
#include <ZumoMotors.h>
#include <Wire.h>
#include <ZumoReflectanceSensorArray.h>
#include <Pixy2I2C.h>
// this limits how fast Zumo travels forward (400 is max possible for Zumo)
#define MAX_TRANSLATE_VELOCITY  400
#define NUM_SENSORS 6
#define LED 13
#define QTR_THRESHOLD  1500 // microseconds
#define REVERSE_SPEED     400 // 0 is stopped, 400 is full speed
#define TURN_SPEED        400
#define FORWARD_SPEED     400
#define REVERSE_DURATION  400 // ms
#define TURN_DURATION     268 // ms
unsigned int sensor_values[NUM_SENSORS];
//ZumoReflectanceSensorArray reflectanceSensors;
ZumoReflectanceSensorArray sensors(QTR_NO_EMITTER_PIN);
Pixy2 pixy;
ZumoMotors motors;
PIDLoop panLoop(350, 0, 600, true);
PIDLoop tiltLoop(500, 0, 700, true);
PIDLoop rotateLoop(300, 600, 300, false);
PIDLoop translateLoop(400, 800, 300, false);
  Serial.print("Starting...\n");
  // initialize motor objects
  motors.setLeftSpeed(0);
  motors.setRightSpeed(0);
  // need to initialize pixy object
  pixy.init();
  // user color connected components program
  pixy.changeProg("color_connected_components");
// Take the biggest block (blocks[0]) that's been around for at least 30 frames (1/2 second)
// and return its index, otherwise return -1
int16_t acquireBlock()
  if (pixy.ccc.numBlocks && pixy.ccc.blocks[0].m_age>30)
    return pixy.ccc.blocks[0].m_index;
  return -1;
// Find the block with the given index.  In other words, find the same object in the current
// frame -- not the biggest object, but he object we've locked onto in acquireBlock()
// If it's not in the current frame, return NULL
Block *trackBlock(uint8_t index)
  uint8_t i;
  for (i=0; i<pixy.ccc.numBlocks; i++)
    if (index==pixy.ccc.blocks[i].m_index)
      return &pixy.ccc.blocks[i];
  return NULL;
    sensors.read(sensor_values);
while (sensor_values[5] < QTR_THRESHOLD)
  static int16_t index = -1;
  int32_t panOffset, tiltOffset, headingOffset, left, right;
  Block *block=NULL;
  pixy.ccc.getBlocks();
  if (index==-1) // search....
    Serial.println("Searching for block...");
    index = acquireBlock();
    if (index>=0)
      Serial.println("Found block!");
  // If we've found a block, find it, track it
  if (index>=0)
     block = trackBlock(index);
  // If we're able to track it, move motors
  if (block)
    // calculate pan and tilt errors
    panOffset = (int32_t)pixy.frameWidth/2 - (int32_t)block->m_x;
    tiltOffset = (int32_t)block->m_y - (int32_t)pixy.frameHeight/2;
    // calculate how to move pan and tilt servos
    panLoop.update(panOffset);
    tiltLoop.update(tiltOffset);
    // move servos
    pixy.setServos(panLoop.m_command, tiltLoop.m_command);
    // calculate translate and rotate errors
    panOffset += panLoop.m_command - PIXY_RCS_CENTER_POS;
    tiltOffset += tiltLoop.m_command - PIXY_RCS_CENTER_POS - PIXY_RCS_CENTER_POS/2 + PIXY_RCS_CENTER_POS/8;
    rotateLoop.update(panOffset);
    translateLoop.update(-tiltOffset);
    // keep translation velocity below maximum
    if (translateLoop.m_command>MAX_TRANSLATE_VELOCITY)
      translateLoop.m_command = MAX_TRANSLATE_VELOCITY;
    // calculate left and right wheel velocities based on rotation and translation velocities
    left = rotateLoop.m_command + translateLoop.m_command;
    right = -rotateLoop.m_command + translateLoop.m_command;
   //left = -rotateLoop.m_command + translateLoop.m_command;
   //right = -rotateLoop.m_command + translateLoop.m_command;
    // set wheel velocities
    motors.setLeftSpeed(left);
    motors.setRightSpeed(right);
    // print the block we're tracking -- wait until end of loop to reduce latency
    block->print();
 if (sensor_values[5] > QTR_THRESHOLD)
    // if leftmost sensor detects line, reverse and turn to the right
    motors.setSpeeds(-REVERSE_SPEED, -REVERSE_SPEED);
    delay(REVERSE_DURATION);
    motors.setSpeeds(TURN_SPEED, -TURN_SPEED);
    delay(TURN_DURATION);
    motors.setSpeeds(FORWARD_SPEED, FORWARD_SPEED);
  // {motors.setSpeeds(FORWARD_SPEED, FORWARD_SPEED);
if (sensor_values[0] > QTR_THRESHOLD)
  else // no object detected, stop motors, go into search state
    rotateLoop.reset();
    translateLoop.reset();
    motors.setLeftSpeed(400);
    motors.setRightSpeed(400);
    index = -1; // set search state
This tells us nothing.
For hints on how to get informed help, please read and follow the directions in the "How to use this forum" post.
Thank you for your reply, jremington. What information can i supply you with that will better describe the problem we are having? Our program compiles, but when we run it, only the line following sensor array on the Zumo works. The pixy2 does not. If we only upload the pixy2 sample code, it works fine. We tried combining that code with our line following code but when we do, the pixy2 doesn't do anything. We are looking for what we should add to get both sensors working at the same time. We ran into a dead end on the pixy2 forum.... they told us they only support the pixy2 device and didn't offer any advice other than we should consider using a "while" statement. We added it, based off tutorials, videos, and trial&error but we have had no success.
Your program produces serial output that you haven't shared. It's hard to help you when you don't share EVERYTHING you can see.
You COULD add more serial output, to see mare about what is happening.
As described in the "How to use this forum" post, you should state which Arduino you are using, provide a wiring diagram (hand drawn, not Fritzing), an example of the program output illustrating the problem, etc.
Please read it.
That sounds good. We will work on providing the serial output and the drawings as requested. If there is anything else we can add that will paint the full picture, we absolutely will!! We also want to thank you both for taking the time to reply to us and sharing your feedback. We do ask for your patience though, we have a competition against high school students this weekend and we are looking to win :slight_smile: so we might not get to submit the drawings and serial output information before the competition, but we will post it as soon as we can.
