Combining SD Card + ultrasonic sensor to count cars
Hi Guys,
Actually I´ve got the problem, that my code doesn´t work correctly…
The aim is to count the cars which are driving next to our house 24/7.
Problem description:
SD card inizialises correctly. After that the sensor should count the cars and write the result as a txt-file on the SD card. But the counting doesn´t work.
#include <SD.h>
#include <SPI.h>
File myFile;
int pinCS = 10;
// defines pins numbers for the sensor (Ultraschall)
const int trigPin = 9;
const int echoPin = 10;
// defines variables long duration;
long duration;
int distance;
float counter = 0;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(pinCS, OUTPUT);
  // SD Karte initialisieren...
  if (SD.begin())
    Serial.println("SD Karte ist bereit.");
  } else
    //Testen indem ich Karte entferne
    Serial.println("SD Karte kann nicht initialisiert werden.");
    return;
// Clears the trigPin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin on HIGH state for 10 micro seconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance= duration*0.034/2;
  Serial.print("Distanz: ");
  Serial.println(distance);
  delay(900);
if (distance < 50 && distance > 10){
  counter = counter + 1;
  Serial.print("Autos: ");
  Serial.println(counter);
  delay(900);
  myFile = SD.open("AnzahlAutos.txt", FILE_WRITE); //Starte mit dem Schreiben
  if (myFile) {
    myFile.print("Autos: ");
    myFile.println(counter);
    myFile.close(); // File schließen.
  // Wenn das File nicht aufgeht, muss ein Fehler kommen:
  else {
    Serial.println("FehlerbeimÖffnen.txt");
  delay(3000);
Would be great if you have some ideas/solutions for me. To be honest I´m really new into Arduino and I worked for this sketch a few days and read a lot…but I can´t find the solution (maybe I´m searching for the wrong things).
Thanks a lot for your assistance (every assistance ideas, articles, etc.) :slight_smile:
Cheers
Tobias
What does the serial monitor show?
int pinCS = 10;
That looks like a problem
