Combining Servo + LDR, a Button, and a Potentiometer
Right now I have three separate codes, and I have set up my Arduino Uno and the breadboard to run each one (I just have to upload each code separately). The first code is to control a servo with a photoresistor. The second code is to control a servo with a potentiometer. The third code is to control an LED with a button. My goal is to combine the three so that the servo is controlled by the photoresistor unless I push the button. Then it is controlled by the potentiometer. Most of the code was found online. The LED portion of the third code is not necessary, and the third code needs to be modified to change the control of the servo by a button PRESS (i.e. HIGH to LOW or LOW to HIGH) not just holding the button down. Unfortunately, I am inexperienced with coding, so any help you can give me would be greatly appreciated!
First Code (photoresistor)
#include <Servo.h>
Servo ShutterServo;
const int photoresistor = 1;
const int motor = 12;
int photoresistorValue = 0;
int outputValue = 0;
float nice = 0.09;
float myValue;
  ShutterServo.attach(motor);
  photoresistorValue = analogRead(photoresistor);
  myValue = float(map(photoresistorValue, 0, 100, 0, 180));
  outputValue += int(myValue - outputValue) *nice;
  Serial.print("sensor = ");
  Serial.print(photoresistorValue);
  Serial.print("\t output = ");
  Serial.println(outputValue);
  ShutterServo.write(outputValue);
  delay (10);
Code Two (potentiometer)
#include <Servo.h>
Servo ShutterServo;
int potpin = 0;
int val;
  ShutterServo.attach(12);
  val = analogRead(potpin);
  val = map(val, 0, 1023, 0, 179);
  ShutterServo.write(val);
  delay(15);
Code Three (button)
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
Moderator edit: [code][/code] tags added. (Nick Gammon)
Read this before posting a programming question
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the # button above the posting area.
MBEller99:
#include <Servo.h>
Servo ShutterServo;
float nice = 0.09;
float myValue;
Serial.print("sensor = “);
Serial.print(”\t output = ");
delay (10);
**Code Two (potentiometer)**
#include <Servo.h>
Servo ShutterServo;
int potpin = 0;
int val;
  delay(15);
**Code Three (button)**
void loop(){
    // turn LED on:
  else {
    // turn LED off:
So, What is the problem? You know how to read a switch state. You know how to take action based on that state.
You know how to read a potentiometer value and move a servo.
You know how to read an LDR and move a servo.
Do one of these tasks in the if block and the other one in the else block.
When that doesn't work as expected, learn how to detect transitions and to count switch presses.
You'll never get better if you don't understand the code and try stuff.
Okay that was easier than I thought. The if/else statement worked perfectly. Now my only problem is the button. I can't figure out how to count like you said. Can you point me in the right direction?
count++;
int prevState = LOW;
int currState;
byte count = 0;
   currState = digitalRead(switchPin); // I really doubt that you have a button attached to the pin
   if(currState != prevState)
      if(currState == HIGH)
         count++;
   prevState = currState;
   if(count >= 2)
     count = 0;
   if(count == 0)
      // Do thing 1
      // Do thing 2
