Over the last couple of weeks I've put together a sketch using an Arduino Uno, which I'll swap out later for the smaller Nano. The sketch controls Leds and their sequence using states, & a small servo motor.
It basically has three stages.
No buttons pressed, servo doesn't move and leds blink slowly
Button A pressed, servo moves 35 degrees and leds blink slightly faster
Button B pressed, servo moves 83 degrees and leds blink really fast
The sketch works without any issue.
[code]
#include<Servo.h>
// RED LEDS wired to buttonA & B press
int ledPinRA = A0; // the number of the LED pin
int ledPinRB = A1; // the number of the LED pin
Servo myservo; // create servo object to control servo
int buttonApin = 2;
int buttonBpin = 4;
int pos = 0; // set initial servo position to 0
int buttonAstate = 0; // variable for reading pushbutton status
int buttonBstate = 0;
by noiasca
https://forum.arduino.cc/index.php?topic=666044
const uint16_t intervalSLOW[] {1000, 1000, 1000, 1000, 1000, 1000, 1000, 100}; // time to wait in each intervall
const uint16_t intervalMEDIUM[] {400, 400, 400, 400, 400, 400, 400, 100};
const uint16_t intervalFAST[] {100, 100, 100, 100, 100, 100, 100, 100};
const byte ledPinA = 5;
const byte ledPinB = 6;
const byte ledPinC = 7;
const byte ledPinD = 8;
const byte ledPinE = 9;
const byte ledPinF = 10;
const byte ledPinG = 11;
void handleLedsSLOW()
static uint32_t previousMillis = 0;
static byte state = 7;
if (millis() - previousMillis >= intervalSLOW[state])
// it's time for next state
state++;
state = state % 8;
Serial.print(F("state=")); Serial.println(state);
// act according state
switch (state)
case 0:
digitalWrite(ledPinA, HIGH);
digitalWrite(ledPinB, LOW);
digitalWrite(ledPinC, LOW);
digitalWrite(ledPinD, LOW);
digitalWrite(ledPinE, LOW);
digitalWrite(ledPinF, LOW);
digitalWrite(ledPinG, LOW);
case 1:
digitalWrite(ledPinA, LOW);
digitalWrite(ledPinB, HIGH);
case 2:
digitalWrite(ledPinC, HIGH);
case 3:
digitalWrite(ledPinD, HIGH);
case 4:
digitalWrite(ledPinE, HIGH);
case 5:
digitalWrite(ledPinF, HIGH);
case 6:
digitalWrite(ledPinG, HIGH);
case 7:
previousMillis = millis();
void handleLedsMEDIUM()
if (millis() - previousMillis >= intervalMEDIUM[state])
state++;
state = state % 8;
switch (state)
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
void handleLedsFAST()
if (millis() - previousMillis >= intervalFAST[state])
state++;
state = state % 8;
switch (state)
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
myservo.attach(3);
pinMode(3, OUTPUT); // initialize the servo pin as an output
pinMode(buttonApin, INPUT_PULLUP); // initialize the button A pin as an input
pinMode(buttonBpin, INPUT_PULLUP); // initialize the button B pin as an input
pinMode(ledPinA, OUTPUT); // initialize the LED1 pin as an output
pinMode(ledPinB, OUTPUT); // initialize the LED2 pin as an output
pinMode(ledPinC, OUTPUT); // initialize the LED3 pin as an output
pinMode(ledPinD, OUTPUT); // initialize the LED4 pin as an output
pinMode(ledPinE, OUTPUT); // initialize the LED5 pin as an output
pinMode(ledPinF, OUTPUT); // initialize the LED6 pin as an output
pinMode(ledPinG, OUTPUT); // initialize the LED7 pin as an output
pinMode(12, OUTPUT); // sets the digital pin 12 as output for 2 SLIDE switch LEDS
pinMode(ledPinRA, OUTPUT); // initialize the LED pin as an output
pinMode(ledPinRB, OUTPUT); // initialize the LED pin as an output
digitalWrite(12, HIGH); // sets the digital pin 12 on
buttonAstate = digitalRead(buttonApin); // read the state of button A value
buttonBstate = digitalRead(buttonBpin); // read the state of button B value
// servo position
if ((buttonAstate == HIGH) && (buttonBstate == HIGH)) {
myservo.write(0);
// LED controls
handleLedsSLOW(); // checks if something is todo with the LEDs
//do other important stuff here
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (digitalRead(buttonAstate) == HIGH) {
// turn LED on:
digitalWrite(ledPinRA, LOW);
// turn LED off:
if (digitalRead(buttonBstate) == HIGH) {
// turn LED on:
digitalWrite(ledPinRB, LOW);
// turn LED off:
else if (buttonAstate == LOW) { // check if button A is pressed
myservo.write(35); // if it is rotate servo to 35 degrees
handleLedsMEDIUM(); // checks if something is todo with the LEDs
// turn LED on:
digitalWrite(ledPinRA, HIGH);
// turn LED off:
else {
(buttonBstate == LOW) // check if button B is pressed
; myservo.write(83); // if it is rotate servo to 83 degrees
handleLedsFAST(); // checks if something is todo with the LEDs
// turn LED on:
digitalWrite(ledPinRB, HIGH);
// turn LED off:
delay(100); // waits for a second
[/code]
What Iām doing now is adding sound to the project. I have a BY8301-16p module loaded with 3 sound files, 01.mp3, 02.mp3 & 03.mp3, & using the Nano rx and tx pins, I can get the module to play the sound i want & loop it using the following sketch.
[code]
==================================== BB-8 PADAWAN DOME ============================================
====================================== Version 0.07 =============================================
Version History
0.01 - Original Sketch by DavidScott
0.02 - r0n_dL added annotations & variable for PIN_sound_BUSY as suggested by DavidScott
0.03 - r0n_dL reassigned pins to align with Padawan control system
- Changed SoftwareSerial pins (RX/TX) 10/9 to 8/4
0.04 - Change pinMode for PIN_trigger to INPUT_PULLUP to resolve issue using with Pro Micro
0.05 - Added support for the BY8301-16P and BY8001-16P sound modules
0.06 - Using an updated version of MP3FLASH16P (MP3Flash16Pv2) which now removes static serial
mappings out of the .cpp file
- Add support to select between using 3 different sound modules by changing 1 variable
0.07 - Changed hard coded serial port in library
r0n_dL IMPORTANT NOTE & RECOGNITON: This sketch was written by DavidScott. Thanks for a great base!
// DavidScott's original comment below
// This example plays a random file (001 to 010) forever
// It uses the playFileAndWait() command so no extra code is needed, it will play another file as soon as
// the previous one finishes. If it doesn't work, try reversing the RX/TX wires as that's probably going to be
// the most common mistake. Also check that the player's BUSY line is connected to Arduino pin 3
// Finally check that the player has a speaker connected as well as ground and VCC
r0n_dL NOTES: Basic sketch provided by DavidScott to give sounds and synchronized voice lights for
scale BB-8 Domes
REQUIRED Libaries to make this sketch work:
MP3Flash16Pv2 Library
https://github.com/r0ndL/MP3Flash16Pv2
BY8x0116P Library
https://github.com/r0ndL/BY8x0116Pv2
// SET AUDIO OPTIONS...
// NOTE: This sketch currently supports 3 different sound modules (MP3-FLASH-16P, BY8001-16P, BY8301-16P)
#define AUDIO1 2 // 1=MP3-FLASH-16P
// 2=BY8001-16P or BY8301-16P
// INCLUDE LIBS AND DECLARE VARIABLES...
#include "SoftwareSerial.h"
SoftwareSerial MP3Serial(A4, A5); // SoftwareSerial port assignments (RX, TX) to communicate with sound module
#if (AUDIO1==2)
//settings for BY8001-16P or BY8301-16P module...
#include "BY8x0116Pv2.h"
BY8x0116Pv2 myPlayer(MP3Serial); // Use SoftwareSerial as the serial port
#else
//settings for MP3-FLASH-16P...
#include "MP3Flash16Pv2.h"
MP3Flash16Pv2 myPlayer(MP3Serial); // Use SoftwareSerial as the serial port
#endif
// ARDUINO PIN ASSIGNMENTS...
// Default Pin Assignments - BASIC WIRING in NOTES
#define PIN_sound_BUSY A3 //Connect to BUSY pin on sound module
// ADDITIONAL SOUND OPTIONS...
#define number_of_sounds 3
//Serial.begin(9600); // you can ommit this line
MP3Serial.begin(9600);
myPlayer.init(PIN_sound_BUSY); // Init the player with the MP3 BUSY pin connected to Arduino pin defined
//randomSeed(analogRead(0));
if (!myPlayer.isBusy()) {
myPlayer.playFile(1, 10);
//delay(100);
[/code]
I've now combined these 2 sketches & the buttons, servo, sounds & LEDS sequence just as they should BUT the servo has started twitching/pulsing occasionally when the sound file loops. Sometimes it's just one twitch, sometimes 2 or 3, sometimes no twitch at all.
[code]
Version History
scale BB-8 Domes
BY8x0116P Library
#if (AUDIO1==2)
#else
#endif
#include<Servo.h>
int buttonApin = 2;
int buttonBpin = 4;
by noiasca
state++;
state = state % 8;
switch (state)
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
state++;
state = state % 8;
switch (state)
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
state++;
state = state % 8;
switch (state)
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
myservo.attach(3);
// servo position
myservo.write(0);
//delay(100);
// LED controls
// turn LED on:
// turn LED off:
// turn LED on:
// turn LED off:
myPlayer.playFile(2, 10);
//delay(100);
// turn LED on:
// turn LED off:
else {
myPlayer.playFile(3, 10);
//delay(100);
// turn LED on:
// turn LED off:
[/code]
I have found that when I remove the following lines from the sketch, (its in 3 seperate sections to control the 3 sounds), the issue with the servo stops, but I also can't play the sounds without them.
//delay(100);
Any help would be greatly appreciated by this Arduino newbie.
