Combining Sketches
I am a student and new to Arduino microcontroller. My project is a Wireless Environment System which includes sensors (photocell, temperature and humidity). I decided to write the sketches (program) in section and now I have to combine them.
Can someone give me suggest on how to combine my sketches so they can work together.
http://arduino.cc/forum/index.php/topic,97455.0.html You read this, didn't you?
Ctrl+C Ctrl+V
Here's one way:
Put all the parts that go before void setup together. Put all the parts in void setup together. Write a blink without delay section to run the rest quasi- concurrently:
add these to your declarations: unsigned long previousMillis(); byte sketchSelect = 0;
void loop(){
if (millis() >=previousMillis){
previousMillis = previousMillis+100; // each gets 100mS, then next one start
sketchSelect = sketchSelect +1;
if (sketchSelect == 4){ sketchSelect = 1;}
switch (sketchSelect){
case 1:
// sketch 1
case 2:
// sketch 2
case 3:
// sketch 3
} // end switch
} // end loop
This is Grumpy Mike's page:
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
