I NEED HELP COMBINING CODES FOR VOLTAGE, CURRENT, PROXIMITY, LEVEL, ELECTRIC MOTOR
//ACCELEROMETER
int x, y, z;
//CURRENT SENSOR
const int analogInPin = A2;
const int avgSamples = 10;
int sensorValue = 0;
float sensitivity = 100.0 / 500.0;
float Vref = 2500;
//VOLTAGE SENSOR
int value = 0;
float voltage;
float R1 = 47000.0;
float R2 = 33000.0;
//PROXIMITY SENSOR
#include <SharpIR.h>
#define ir A0
#define model 20150
SharpIR SharpIR(ir, model);
//FLOWRATE
int flowPin = 3;
double flowRate;
volatile int count;
//ELECTRIC MOTOR
const int MotorPinA = 12;
const int MotorSpeedPinA = 3;
const int MotorBrakePinA = 9;
const int MotorPinB = 13;
const int MotorSpeedPinB = 11;
const int MotorBrakePinB = 8;
const int CW = HIGH;
const int CCW = LOW;
const int showComments = 1;
//ACCELEROMETER
//CURRENT SENSOR
Serial.begin(19200);
//VOLTAGE SENSOR
Serial.begin(57600);
//PROXIMITY SENSOR
Serial.begin(74880);
pinMode(MotorPinA, OUTPUT);
pinMode(MotorSpeedPinA, OUTPUT);
pinMode(MotorBrakePinA, OUTPUT);
//FLOWRATE METER
pinMode(flowPin, INPUT);
attachInterrupt(0, Flow, RISING);
//ELECTRIC MOTOR
pinMode(MotorPinB, OUTPUT);
pinMode(MotorSpeedPinB, OUTPUT);
pinMode(MotorBrakePinB, OUTPUT);
Serial.begin(230400);// seial monitor initialized
//ACCELEROMETER
x = analogRead(0);
y = analogRead(1);
z = analogRead(2);
Serial.print("accelerations are x, y, z: ");
Serial.print(x, DEC);
Serial.print(" ");
Serial.print(y, DEC);
Serial.print(" ");
Serial.println(z, DEC);
//CURRENT SENSOR
for (int i = 0; i < avgSamples; i++)
sensorValue += analogRead(analogInPin);
delay(50);
sensorValue = sensorValue / avgSamples;
float voltage = 4.88 * sensorValue;
float current = (voltage - Vref) * sensitivity;
Serial.print(voltage);
Serial.print("\n");
sensorValue = 0;
//VOLTAGE SENSOR
value = analogRead(A0);
voltage = value * (5.0/1024)*((R1 + R2)/R2);
Serial.print("Voltage =");
Serial.println(voltage);
//PROXIMITY SENSOR
delay(2000);
unsigned long pepe1=millis();
int dis=SharpIR.distance();
Serial.print("Mean distance: ");
Serial.println(dis);
unsigned long pepe2=millis()-pepe1;
Serial.print("Time taken (ms): ");
Serial.println(pepe2);
//FLOWRATE METER
count = 0;
interrupts();
delay (1000);
noInterrupts();
flowRate = (count * 2.25);
flowRate = flowRate * 60;
flowRate = flowRate / 1000;
Serial.print(flowRate);
Serial.println("mL/Second");
void Flow()
count++;
//ELECTRIC MOTOR
brake('A', 0); // release brake
brake('B', 0); // release brake
moveMotor('A', CCW, 100);// motot A rotate CCW at 100 PWM value
moveMotor('B', CW, 145);// motot B rotate CW at 145 PWM value
delay(3000);
brake('A',1);
brake('A',0);
brake('B',1);
brake('B',0);
moveMotor('A', CW, 255);
moveMotor('B', CCW, 145);
delay(5000);
brake('A',1);
void moveMotor(char motor, int dir, int speed)
int motorPin;
int motorSpeedPin;
if(motor =='A')
motorPin = MotorPinA;
motorSpeedPin = MotorSpeedPinA;
}else{
motorPin = MotorPinB;
motorSpeedPin = MotorSpeedPinB;
digitalWrite(motorPin, dir);// set direction for motor
analogWrite(motorSpeedPin, speed);// set speed of motor
}//moveMotor end
void brake(char motor, int brk)
if(motor =='A')
digitalWrite(MotorBrakePinA, brk);// brake
}else{
digitalWrite(MotorBrakePinB, brk);// brake
